the_tool_man
Upstate South Carolina
Yes hemholtz chamber aka ¼ wave. It works pretty well considering i didn't do any math i just copied what some of the guys on one of the forum's for a Silverado in my searching. My 2k rpm drone is gone. My afm still is annoying but will be going away eventually.
Sent from my SM-N950U using Tapatalk
They're pretty effective over a fairly wide range of RPM. So getting the length exactly right isn't that important. On my car I had to make the tubes a little shorter than theoretically optimum, because the transmission crossmember was in the way. And besides, the exact frequency depends on the temperature of the exhaust gasses, which I could only guess at when doing the math. Still, it worked very well.
The only downside was trying to sell the H-pipe later. No one could understand what the pipes were for, and didn't want to buy it modded. The guy who bought it cut them off.
Sam Harris
Morons!
...It works pretty well considering i didn't do any math...
Derick
Indy Suburbs
Got the burb back from the mechanic. Installed junkyard diff with a warranty, and it doesnt seem like it drives on rumble strips anymore. Just had a drive home, so need to put more miles on it to get a full feel of it.
Derick
Indy Suburbs
Le sigh. Now I have a misfire. fml.
Actually, its somewhat of a good thing. This MIGHT have been a long standing issue with my truck and an odd, non linear power curve. It would get up to 3k just fine...then kinda stumble, and then kinda sorta pickup again after 3700...it felt like a minor problem, but never ran rough and never threw a code. So now, I'm hoping it's just the coil pack and that will sort out a long standing issue.
So right now, if I get my foot into it, full steam, once it hits the 5k redline, it throws a code. So I'm really thinking bad coilpack.
whats the code?
Derick
Indy Suburbs
P0306 and a new coil didn't help it any. Goes and hard shifts too.. But sometimes clears itself
osidesurfer365
San Diego
Front and rear brake pads. Been using Wagner OEx pads last couple times and been liking them.
veteran111
