Black Betty 2018 Z71 Silverado....build
I'm sure you'll get new wood spokes. ;)
as long as it's straight, lol they quoted me about $150, apparently these wheels that are only about 3 years old are no longer available so not much choice either get it fixed or fork over more for a new set.
went by 4wheel parts and they quoted me $4100 for the 4.5" lift install and alignment with bilstein 5100's all the way around
I need to source the oem control arms both sides upper & lower because the drop kit had it's own arms and the oem's are gone
then I need wheels and tires....
Bear77
South FL
Any particular reason you didn’t get them all from same place?
rockauto didn't have the upper left in stock, so I had to order elsewhere, picked ebay and the seller just canceled the order a minute ago so I just bought a clean looking used one out of Texas instead $99 shipped
So I am looking at trying to do these wheels and tires, who's good at math @swathdiver any idea what tire height that would give me
FUEL MAVERICK D610 GLOSS BLACK MILLED
22X9.5 6X135MM/5.5" 20MM
TOYO OPEN COUNTRY AT II
285/45R22 114H
285/45R22 114H
View attachment 258987 View attachment 258988
Mathematically, 32.10 inches on a nine inch wide wheel. Wheel offset is 11 mm less than standard GM so the wheel will reach 5mm less into the wheel well compared with a GM 22x9 and extend 17mm past the same wheel on the outside. Nice wheels. Those Open Country tires are well thought of too.
okay what about a 325/55r22 ? looking at the pirelli scorpion atr
and that wheel I think comes in a offset of 25 also
can't make up my mind, lol
looks like these would give me almost 33"
fuel maverick d610 20X9
yokohama geolander a/t 275/60r20
the shop is recommending a 285/55/r20 or 305/55/r20 I can't find any H rated tires highest I can get is T, I found 1 285/50/R20 H yokahama
stumped, now I don't want to be limited by the tires
cant find any tires that will do what I want so I since I already ordered the control arms I might just put it back to stock height and put on 2" drop shackles on the back to level it out like I did the 03, put some bilsteins on it and maybe some nice wheels and tires and call it a day. :shrug:
gat0r
DFW
do you routinely drive over 118mph & up to 130?
you are looking at all terrain tires, 118 should be decent....in theory
its cali , not the autobahn :anitoof:
also listed as T for 285/55r20:
BFG All-Terrain T/A KO2 Tire
Pirelli Scorpion All Terrain Plus
plus a few china tires, but i wouldnt trust those at speed
drop down to 50 series & options open up a lot more for H speed for both sizes
nitto, yoko, goodyear
It's been thirty some years, but if I remember my schooling right, the speed rating is given to a tire that runs at maximum weight at that given speed for one hour. Makes sense as I used to routinely hit almost 150 mph in my Buicks with S-Rated tires way back then. Never stayed up there for very long, too scary but we did routinely cruise on the highway at 104 mph, which was 0-boost on the gauge for the intercooled motors. Never a problem with those BFG Radial T/As. So that being said, occasional forays into the triple digits shouldn't be a problem. Couple years ago we spent about 2 hours at 80-95 mph getting to my daughter's recital after work and running with the flow of country traffic! No problems then either with the KO2s.
ya, I guess you are right I have exceeded the yukons tires many times lol
I think the closest I am going to get is a toyo open country AT III 295/55r20 120T
Drewphil
