St. Louis
Oh, last night when I went and got gas at the Mobil station near me, their E85 ($1.84 gal) pumps had a bag over the handles and were out of order, so I got their premium plus @$2.65 gallon. Took 26 gallons and the alcohol % went from 72 down to 17.
I haven't ran 93 octane in a while, usually get E85 when I can.
Yeah but, we still have our plastic wire loom from the factory.....
kbuskill
NE. FL.
Need one anyway, right? Aren’t you planning some runs in the 150+ range Dub?
Lol
Not enough clear highway, HP nor safe aerodynamics for 150!
But, I am kinda plotting a more appropriate driveshaft. I've hit the 120s LOTS of times and felt nothing amiss, but I'd still consider that tempting fate. I'm fine going "only" 120ish. Getting there quicker is what interests me.
Lol
150 shouldn't be bad at all (if you can get it there) I have ran mine 130+ and she sails smooth as glass, you do get some noticeably increased wind noise
***pretty sure you would need different gearing anyway the 3.42 3.73 just isn't going to get there without increased rpm, @swathdiver what would it take 7k 8k???
Well, your Denali would be turning about 4600 rpms (mathematically) at 150 mph in 5th gear.
so basically if it was lowered to 1' off the ground the roof was cut off it might hit 150 :p:p:p
I was thinking of this and on another forum saw a fellow also wanting to cruise at 110 and came across this photo:
If true, this fellas truck needed a whole lot more rpms to overcome the drag at that speed. I know he was in Texas and believe that this was a GMT900 6.2 Silverado and those have 3.73 gears.
ya that's kind of why I figured more rpms obviously in a lower gear to overcome the drag, the top speed in these trucks is approx 137, in stock form, the main limiting factor being the rpms
Drewphil
