disconnecting the battery will not make the transmission relearn.
Can I get anyone with a 2007 Yukon Denali and a Tech2 to confirm that they can see that option? Is it just my Tech2? I am pretty sure the connection is fine as I was able to successfully reprogram the ECM/TCM. The Tech2 reports back the correct software IDs that were not there before I did the update. I can also perform other diagnostic checks and the Tech2 reads all the transmission values when I got into the sensor option (temp, line pressure, etc).
![20200902_153723[1].jpg 20200902_153723[1].jpg](https://www.tahoeyukonforum.com/data/attachments/251/251023-78b3920c2daab9bd101071bc44393b8e.jpg)
Not like the engine sensors?disconnecting the battery will not make the transmission relearn.
Nope, the only thing that can be reset normally is if it throws a transmission code, then you could clear it the same way you would a check engine light.Not like the engine sensors?
Hmm, I've never had to clear a locked up vagNope, the only thing that can be reset normally is if it throws a transmission code, then you could clear it the same way you would a check engine light.
how do I know? lol
well when you wreck a transmission like a virgin vag and it locks up on you, you can clear it and try again lol
I knew plenty of locked up vag’s.... buncha dick teases....Hmm, I've never had to clear a locked up vag
Actually, don't think I've even had a locked up vag, or know what one is....lol
I think he meant a wrecked vag.Hmm, I've never had to clear a locked up vag
w/ the rain that just blew in, we went down to 60's tonight. looks like low will be in 50's for lows, later this week
highs, will be 75-90 this week will be really nice
Roger that! Done and Done. Now off to driving the beast. Help is very appreciated, for sure! I had seen that before when I was hunting around, but was looking for Fast Learn Adapt specifically. Guess I should've read between the lines...huh?I went out to mine and took these photos for you:
View attachment 256225 View attachment 256226 View attachment 256227 View attachment 256228
I thought he wrecked the vag and THEN it locked up.I knew plenty of locked up vag’s.... buncha dick teases....
Yeah they have a limp mode just like the engine.I have had transmissions throw a code and then lock up and refuse to shift, clear the code and walla working again until it throws the code again
From the pan plug or the filter? I have a 4'x5' piece of cardboard that I keep around to slide under vehicles when I change oil just in case.I changed the oil this morning....and for some reason both times ive changed it on this truck ive made exon valdes underneath it which makes no sense since its super easy
I use a wide one like this, works great.first one, then the other haha. It got everywhere. First I missed the drain plug pure with the opening for my pan, then it started to drip at the pan, but the distance between the stream and drip was wider then my oil container opening. the filter wasnt as bad until I got it off and then it slipped and ran over the sway bar and my hand. Even with my piece of cardboard, i soaked it in oil. Then the oil catch pan i have doesnt tighen the cap all the way so it slowly leaks if i dont store it at an angle.
long story short, i need a new oil catch pan, looking at a flat one with all the drain on top and an extendable funnel. i think that will help my case
