I find it's usually the 1st cold snap that kills them.yep spring and fall takes out a lot of batteries
Yeah, you got that Pa cold! That's that Alaska cold--same as Joisey lol!Fo sho.![]()
Or Wisco cold....Yeah, you got that Pa cold! That's that Alaska cold--same as Joisey lol!
Fur real? Some of y'all are having cold snaps?
Nah, just down into the 50’s overnight.Fur real? Some of y'all are having cold snaps?
Isn't that something they should've done? Not you??Okay all...I was able to successfully update the ECM/TCM using my Tech2. As mentioned, it was pretty straightforward...and I dig learning new stuff like that. Engine oil pressure is great and it seems to idle pretty smooth. Happy with the engine rebuild, for sure. Very grateful for the suggestions from the forum gurus.
However, running into a snag with the transmission. (Reminder: 2007 Yukon Denali...no aftermarket mods...6.2...6L80e transmission) The transmission company recommends a Service Fast Learn Adapt procedure be completed. I cannot find this option ANYWHERE in my Tech2? I followed the process, let the transmission get to >158 degrees, did the 3 cycles of Park - Reverse...yada yada.
I went into the Tech2 and entered the following:
-Diagnostics
-Selected Vehicle (2007, K, Yukon)
-Powertrain (selected 6.2)
-TCM
I went to the F5 option (where I had read other makes/models had gone to get their Fast Learn Adapt option), but all I see is Reset Transmission Oil. No option to perform a Fast Learn Adapt. Am I looking in the wrong spot? The transmission company says that not doing this will void the warranty. Ughh!
Can I get anyone with a 2007 Yukon Denali and a Tech2 to confirm that they can see that option? Is it just my Tech2? I am pretty sure the connection is fine as I was able to successfully reprogram the ECM/TCM. The Tech2 reports back the correct software IDs that were not there before I did the update. I can also perform other diagnostic checks and the Tech2 reads all the transmission values when I got into the sensor option (temp, line pressure, etc).
Side note, I had read in one forum something about GM going away from the Fast Learn Adapt on the Tech2...but I cannot confirm this. Wouldn't make sense to me...but I'm also not a GM tech!
Yeah, I did one of those deals where they ship the transmission to me and I install. Saved me a truckload of money in comparison to what others wanted (including the labor). But, I need to do my homework and figure this out.Isn't that something they should've done? Not you??
Are you sure they'd never know? If that's true F* it. I wonder if you pull the battery for awhile--where everything clears, if that would work. Where everything is in learning mode--and just drive it.Yeah, I did one of those deals where they ship the transmission to me and I install. Saved me a truckload of money in comparison to what others wanted (including the labor). But, I need to do my homework and figure this out.
The reality is that I could say I did that procedure and they'd never know. But, I'd rather do it right, if at all possible.
Yup, tempted to do that. As I mentioned before, one of the forums I was looking through last night at around 1am said something about GM going away from that...and to drive it gingerly for about 50-60 miles in town...then the next 200 or so just normal, but no hammering the throttle hard. Let it learn, but don't push it too hard (ie, no drag racing the first 50 miles...)Are you sure they'd never know? If that's true F* it. I wonder if you pull the battery for awhile--where everything clears, if that would work. Where everything is in learning mode--and just drive it.
Absolutely can't hurt. Give it some time, the pros will show up. @swathdiverYup, tempted to do that. As I mentioned before, one of the forums I was looking through last night at around 1am said something about GM going away from that...and to drive it gingerly for about 50-60 miles in town...then the next 200 or so just normal, but no hammering the throttle hard. Let it learn, but don't push it too hard (ie, no drag racing the first 50 miles...)
I just figured I'd open it up to this forum to see if anyone with a 2007 Yukon Denali WAS able to successfully do that Fast Learn Adapt procedure. ...and if so, what was I missing. Couldn't hurt, right?
it's in there in another spot, you will just have to hunt around for it I have seen it before while poking around the tech2Okay all...I was able to successfully update the ECM/TCM using my Tech2. As mentioned, it was pretty straightforward...and I dig learning new stuff like that. Engine oil pressure is great and it seems to idle pretty smooth. Happy with the engine rebuild, for sure. Very grateful for the suggestions from the forum gurus.
-Diagnostics
-TCM
