cfmistry
Usually, but worth checking. Something is going slack and then taking up slack when slowing and going. If the front differential mounts are good, motor mounts are good, and calipers seem to be sliding, I’d be looking at all other parts of the drive train just to be sure.
No tears, the look good, and I don’t hear any noises when spinning the wheels in the air.
GreyStone
So paying real close attention, the clunk is when I let off the brakes after moderate-hard braking. Before I even touch the accelerator. Makes the engine mounts a less likely source right?
Maybe it's your front suspension - when you brake moderately the front end goes down and then comes up on release. - What year truck do you have? Check your exhaust manifold bolts too.
cfmistry
Sway bar bushings are new. Struts and mounts are original with 170k on them... could be the culprit, but how to test??
cfmistry
Thank you to everyone for the help.
So to summarize...
Light clunk noise when coming off the brakes (sounds like the front left). Both in forward and reverse. Don't have to touch the accelerator to hear it.
Caliper sliders are lubed up and in great shape. Rotors and pads have plenty of life left.
New control arms, new tie-rod end, new sway bar bushings. Front diff bushings look in good shape.
I will have my wife turn the steering wheel around and listen for strut bearing noise. Other than that, I can only assume it's a sticky caliper??
fishcop076
