There's a member here, @ScottyBoy , who gets them sometimes and sells them here. He does a great job of separating them from the other oem harnesses, cleaning them up and even labeling them for you. Hopefully he'll get more soon and post them up again.$220 for the harness though... ouch.
Are there any other options?
I heard Black Bar sells these harnesses too, no?
There is no part number for the harness that I know of, you need one from a wrecking yard or one that someone has removed from a wrecked vehicle. There’s a couple write ups in the tech section you should read. I did some work for you and linked them here.PM’d ScottyBoy for some price quotes.
Anyone know the part number for this harness and fan otherwise?
There’s a whole other debate on the best fan, blade count, amp draw yada yada yada. I bought a Flex-a-Lite but don’t remember the model.Thanks a lot for the links. I had read through one of them pretty thoroughly, but completely missed the other one (install into an 01), super informative. My Yukon is an 01, So its very helpful, idk how I missed it before.
Good point on using stock harness, just have to make sure not to get one from a flood vehicle.
Part number for the fan looks like it is: 674-00923
Sure, why not? All the harnesses @ScottyBoy sells are used. I've been a member since 2012, and I've never read 1 negative comment about his work or harnesses that he sells. Matter of fact--I bought one from him myself. It's not installed yet--working on that laterNice. You wouldn’t recommend an OEM used one?
He was talking about the fans themselves.Sure, why not? All the harnesses @ScottyBoy sells are used. I've been a member since 2012, and I've never read 1 negative comment about his work or harnesses that he sells. Matter of fact--I bought one from him myself. It's not installed yet--working on that later![]()
Ohhh. My bad. I still stand by what I said tho. I know pick n pulls sells those fans pretty cheap. Didn't someone say the nnbs fans work on our nbs? Could've sworn I read that here.He was talking about the fans themselves.
I've read the nnbs fans also fit.Yes, indeed the 05-06 e-fans should bolt right in, provided that you have the wider style radiator.
Just opens up more avenues with the parts situation.Ah yes okay, I misread. That would be nice indeed if the NNBS fans fit as well.
