Electric fan conversions
DadsHOE
I'm trying to free up a little power and need some guidance as to a good kit for electric fans. Also a cam swap in the future, would a 220-230° be a good choice?
what year is your vehicle? oe fans will fit and someone on here sells the part to make it work like a factory option you just have have the pcm/ecm flashed to add the option depending on the year I guess.
DIsney
I just installed the GT series fans on my Yuuk. I found teh fans at the pull a part and got the wiring kit from PCMofNC. https://www.pcmofnc.com/product/1999-2002-full-size-truck-dual-fan-conversion-kit-3/
The wiring kit is top notch stuff. So far, very happy with the results. So much quieter. There are times I can tell it's peppier too, like when i'd normally expect the fan to sound like a 737, it's now whisper quiet and frees up some ponies.
Rayyy
Northern California
$220 for the harness though... ouch.
Are there any other options?
I heard Black Bear sells these harnesses too, no?
I would not go with anything other than an OEM harness. All the aftermarket ones have a history of melting during real hot weather. I bought one from LS1fans.com and it completely melted the harness and relays on a 100* day 150 miles from home. Luckily I had AAA Plus. I bought an OEM harness from @ScottyBoy and no problems since. You do have to wire it into the ECM harness but it’s not hard, and then have the pin turned on in the ECM by a tuner like Blackbear or someone local.
Rayyy
Northern California
PM’d ScottyBoy for some price quotes.
Anyone know the part number for this harness and fan otherwise?
There is no part number for the harness that I know of, you need one from a wrecking yard or one that someone has removed from a wrecked vehicle. There’s a couple write ups in the tech section you should read. I did some work for you and linked them here.
https://www.tahoeyukonforum.com/threads/i-installed-e-fans-on-my-2001.28336/
https://www.tahoeyukonforum.com/threads/how-to-install-e-fans.9400/
Also you didn’t mention the year of your truck. There’s slight differences between the 00-02 and 03-06 so read up on that.
Rayyy
Northern California
Thanks a lot for the links. I had read through one of them pretty thoroughly, but completely missed the other one (install into an 01), super informative. My Yukon is an 01, So its very helpful, idk how I missed it before.
Good point on using stock harness, just have to make sure not to get one from a flood vehicle.
Part number for the fan looks like it is: 674-00923
Ihaveatahoetoo
