mikeyss
Longmont, Colorado.
I have been toying with the idea of OVERdriving the alternator because when my K5L fans run on hi, my voltage gauge is around 12V. I can't imagine what UNDERdrivig would do to the charging system.
PPV12HOE
NC
Installed my Powerbond 25% underdrive balancer with an ARP crankbolt.
Badass power mod for the money and time. You can find them for under $250 and only takes about 45 minutes to install......that includes removing/installing the starter.
They're supposed to be good for 13rwhp........the dyno should say on Monday. I will say the butt dyno and going sideways says there is power there
Did you remove the starter to access the flex plate to torque the bolt...?
St. Louis
I have underdrive pulley sets on both of my mustangs. Usually it's a set, because with a smaller crank pulley you will overdrive the other accessories like water pump and alternator. I know our trucks computer controls the alternator charge, so maybe that won't be a problem, but when the engine is in the higher rpms it may spin the alternator or water pump more than it's actually capable of and have a shortened life span or cause cavitation.
Just things to consider
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
kbuskill
NE. FL.
I like different opinions, why would you not overdrive the alt?
I know that on my old Esky I had the 160A alternator rebuilt into a 200A and it didn't like to charge at idle.
I was going to have my buddy rewind it to 260A but he said the bigger you go the less it will charge at idle.
The solution for me was to swap to a smaller pulley on the alternator which alleviated the idle charge problem.
I had also converted the mechanical fan over to dual electric fans on that truck which caused more current draw, obviously.
Did you turn the fans on through the pcm or a switch?
I just wired one to a thermostatic controller and the other one I hooked to a relay that was controlled by the A/C compressor.
Freed up some HP and improved MPG... win, win.
Would you happen to have a diagram to do that? Along with which thermostatic switch you used? I have my fans just sitting in my garage. I'd like to finally get rid of my clutch fans.
kbuskill
NE. FL.
If I were you, and i didn't want to have them programmed to turn on, then i would probably use this...
Hayden Automotive 3654 Adjustable Thermostatic Fan Control https://www.amazon.com/dp/B0049EYE6O/ref=cm_sw_r_other_apa_i_4kITEb6ZFCCNY
It will control 2 fans and has an A/C control input so it will turn the fans on with the A/C.
The temperature setting is adjustable and it has a simple probe that inserts between the fins of your radiator to detect the temperature.
To be on the safe side i would probably use it as a controller to turn on some heavier duty (60A-80A) relays.
Kee Fuller
las vegas
Very productive day, order new springs, rear shocks, swaybars and coilovers. Also picked up these from the junkyard for about 240 bucks. Door panels from an 08 escalade. Gonna put em in next week.
kbuskill
NE. FL.
Should've also gotten better A/C performance at idle since the fans can run at their full speed to cool the condenser whereas the clutch fan is only gonna spin at engine idle RPM. I loved the Taurus fan I put on my S10.
No doubt, she would freeze you out.
Thx. I just remembered I bought the factory fan harness from Scottyboy.......it's been sitting for that long :oops:
kbuskill
NE. FL.
Well if you have the factory relay harness then you could either have your ECM programmed to control them or get the Hayden controller and use it to control the factory relay harness.
Sam Harris
Very cool. But I’m wondering why you wouldn’t just program the BCM (ECM?) to activate the fans based on temp?
Sam Harris
Dammit. That reminded me.. I told him I wanted to buy one he had for sale like 2-3 months ago and I never got a follow up from him. Asked where to send the $$, but never got a response. [emoji53]
Phlipnstik
