Yes he did, thanks. Unfortunately the tune doesn’t reveal any silver bullets, the converter isn’t locked up during shifts. So it looks like the only thing we can do is increase torque management which currently is at 25% of the factory level. I have contacted Performabuilt to ask for a suggestion. Justin mentioned the servo is pretty much in control of how hard the 1-2 shift is; they use the Sonnax billet 2nd gear servo and they utilize their own proprietary shift kit. Hope we can figure this out. Breaking the output shaft hitting second is pretty hard core shifting. Sure is fun to drive though.
Easier on the launches? I know, I know! I wouldn't either probably---just had to say it out loud tho :D:burnout:
randeez
south florida
for el lady :emotions133:
I mean, it’s kind of hard to just throw the $5k I have into this trans and and converter out the window. I really need this to work, and Performabuilt says it should easily do what I need it to reliably. Allan said they specialize in these and they see these in AWD Tahoe’s and Yukon’s with more power than I have and they very rarely break. They’re confidant we can make it work.
It def has earned the name--"THE BEAST"!!
Yeah, who else here has broke an output shaft on their trans? :cool: Only one I know of... The Beast! And it was loud, too. I definitely knew something snapped when it happened.
pretty sure I broke mine twice, transmission shop told me they had never seen a transmission break the way I did it, I wish I had taken pictures when they showed the me the "guts" and I think both times I did it, it was between a 1~2 hard shift accelerations, I cant remember how many times I blew a 4l60 over 10-12 years towards the end I found a better shop and there's seemed to hold up better and I had to teach myself to not jam my pedal so dam hard it was costing me money. Now when I catch myself doing it I tend to ease up a hair I think I have a new record for not breaking a trans since I got the 2012 3 years! :party33: the shop guy knows me and knows I will be back it's just a matter of time lol.
I decided to replace the 3 u-joints that are original while the drive lines are removed. Seemed an opportune time. I replaced one when I broke it a couple years ago. So I ordered some Dana Spicers and new straps and proceeded to begin removing the old ones. They’re the plastic injected ones so I chose an appropriate size socket to catch a cap and since my vise is 6” I didn’t have room for a smaller socket for the “push” side so I used a big nut. I heated the shit out of the yokes until I thought all the plastic had oozed out and began applying pressure and then....snap. There went my 6” HF vise- a jaw broke off. Ordered a better 8” one off Amazon. I will get it Sunday.:mad:
Tough ass U joint--or ****** vise.
PG01
Up here to the right
I decided to replace the 3 u-joints that are original while the drive lines are removed. Seemed an opportune time. I replaced one when I broke it a couple years ago. So I ordered some Dana Spicers and new straps and proceeded to begin removing the old ones. They’re the plastic injected ones so I chose an appropriate size socket to catch a cap and since my vise is 6” I didn’t have room for a smaller socket for the “push” side so I used a big nut.I heated the shit out of the yokes until I thought all the plastic had oozed out and began applying pressure and then....snap. There went my 6” HF vise- a jaw broke off. Ordered a better 8” one off Amazon. I will get it Sunday.:mad:
Like a snake.... lol....oozing plastic
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
How well does it work?
I love it! I have used it many, many times for U-Joints and several ball joint jobs. For ball joints you may need the extra adapter set. For U-joints it is freaking awesome when used with an impact wrench. Snug it by hand, heat the plastic out if needed and press em out. I use it for install too. Works even better with a buddy to hold stuff but I usually work alone.
Sorry for the clutter in your thread @Rocket Man
Bear77
South FL
Thanks
It looks like Ryan at Performabuilt has found the silver bullet. And it looks like it was my fault although I did not know this could be a problem. When I changed the filter at 2000 miles I used RTV on the pan gasket which NOW I find out is a definite no-no. He found silicone blocking the feed for the servo on the pan rail, causing it to not release. Shit. I'm pretty sure I used RTV the first time I installed the trans too, and changed the filter after break-in. That would explain why it didn't last long after I did that the first time. They should say something about that in the instructions.
Here is his email to me today:
Please call me or have your tuner call me and i will explain whats wrong. The servo isnt the problem, the silicone blocking the feed on the panrail is and that isnt letting the servo release properly and you will get hard shifts from that. ALSO line pressure in marks tune needs to be verified that its OEM STOCK PER THE STOCK BIN FILE. My number is *** *** **** with further questions. Please listen and follow my instructions. Had it not been for the silicone blocking the release for the servo you would still be on the road. The line pressure check in the pcm is a safeguard and is required for all of our transmissions.
worleytrev93
