Escalade Roof Rack and How to
St. Louis
Mine don't sit flush/all the way down and they came on my Denali from the factory
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
chilleblanco36
2001 Yukon SLT
I can’t even get mine started. I don’t want to break anything
adventurenali92
Big Bear Lake, ca
Sent from my iPhone using
Tapatalk
You have to put the anchor nuts up and then bolt down the middle bolt into the anchor nut. Then you set the cross rail on top of the anchor nuts on either side and then it slides back into the lock position on the anchor nut. It then is in the right spots for the forward and rear bolt slots.
chilleblanco36
I got that part. I just can’t seem to get the end caps to go in place. [emoji23][emoji2363]
chilleblanco36
They are a pain in the a$$ to put on, I had the same issue when I installed mine.
I loosened both ends and pulled outward while running screws back in. That’s all it took
btheboyscout
