P0301
Kelsda
Kelsda
New Jersey
Didn’t go out last night was in the mid 20s All pulled apart. Anyone have a suggestion what to clean the lower intake with, I've seen people say they bring it to a shop to have it cleaned.
Is it blasted,parts washed, boiled in a solution, brake cleaner, or mineral spirits what would you do? Thanks
liquify33
Houston
That’s not bad IMHO, just make sure mating surfaces are nice and clean. I had some putting in the front corner/#1&2 area but sealed fine. Carb cleaner, wheel brush on a drill, some sandpaper and elbow grease. That’s by far the crappiest part of the job.
Kelsda
Kelsda
New Jersey
What about this can’t see other side do you think this is a crack or just in the casting and what are these holes for not all in the same spot like random one is right on the edge of the injector hole
exp500
That does look like cracks. Is there water on the other side? didn't look like it but you are there. If it is only intake valley you should be ok. Intake Manifolds around here are 35-40 junkyard.I haven't seen one crack before. Try a drop of acetone on crack to verify its not a scratch. It will pull right into crack.
Kelsda
Kelsda
New Jersey
I need this rig fixed the Jeep Wrangler is killing me windy and cold start tomorrow putting back together
GMT800 2005 Tahoe Z71
Navy Supporting Member
Make sure you keep it very clean during reassembly and IMO, you cannot go wrong with Fel-Pro gasket kits. Better than OE in many instances.
Kelsda
Kelsda
New Jersey
Cleaning valve covers for paint noticed inside of left side cover looks like this kind of brown finish wipes off but what is it
inside other side black anyone know why ?
exp500
One valve cover has direct vacuumn, the other air cleaner vacuumn. Clean for a hi mile. What oil you using? Valvolene Dino always makes a dark film as you call it, but the rest stays clean.
Kelsda
Kelsda
New Jersey
Ok upper and lower intake back in sanded,primed,and painted valve covers in spray booth now off to oven to bake on finish (top of furnace) spider was a little tough putting it in hope this is my problem one injector in way of throttle body but installed as per directions can’t really move it
Kelsda
Kelsda
New Jersey
Ok finished up spider conversion code 301 is gone drove and idled nice 45 minutes later boom check engine lit up wtf po154 it’s an 02 bank 2 sensor 1 clear it, back on po152 same bank 2 sensor 1back and fourth every time I cleared it so tonight I cleaned with carb cleaner swap out 02s from left to right good news now I have po134 bank 1 sensor 1 so it is safe to say sensor is bad and found this on the side of the road. Brought it back to the store earning a free pie for my honesty
Kelsda
Kelsda
New Jersey
Cleared P0134 running great no more check engine light did a half assed wax job looking pretty good thanks for all the support
brice715
