Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
Great idea, and it won’t cost a fortune. And I still have the headlights to do. I was actually in the middle of prepping them for paint and deciding on what I’m gonna do different this time when I decided to do the dash swap. I have them both opened and cleaned. But LED’s should be fairly easy to do on the NNBS. They’re already SMD LED’s. Just need to unsolder the old ones and solder in new ones.
Edit: at least SOME of them are. I think.o_O
I know the bulbs in the headlights switch and plenty others are incandescent with blue gel caps over them. Damned things leave burn marks on the insides of the switches.
Sam Harris
It’s been a challenge. I had to drop the tank because it’s all full of crap. It looks like the RTV I used as well as other stuff got all in the tank and filter. I cleaned it up, bought what I thought was the right pump, and it was too tall. So I took it back and checked the other one they had for my truck but got the standard bed and it was taller. Then I called the PO and he said he shortened the stock pump to fit the tank. So now I had to take an Uber to Autozone and I’m on my way back. Gonna try the original rubber gasket or supplied o-ring. And maybe different RTV but just a little where needed.
View attachment 212772 View attachment 212773
Crap
Word. It's one of those all-or-nothing projects that I can't find the initiative to begin.
Yep. I look for the one part of it that I’m afraid of failing at, you know, the hardest item. Because even if you convert all but one item over, you’ve failed and the whole project won’t look right. I saw those solder pads on the DIC switches and they’re the size of a pinhead. I know how easy those are to mess up. I think I’m good.
For me, that "one item" that I'd fail to convert would be the displays at the bottom. I'd guess the color of those is from a film sandwiched in between layers of glass if not the glass itself being tinted.
I changed the displays in my S10's gauge cluster from teal to cobalt blue by applying one or two layers of blue window tint over them. It looked great, but more green or more blue are the only options you have for those screens. @Tonyrodz, did you ever get that tint on your cluster?
Sam Harris
What's a steal?
It was re: your CV self-powered sub box. I just spent the better part of 2 days reading through this entire thread. All I can say is: WOW Mark, you take care of business. I like seeing all the work you’ve done to the Machine, and really appreciate you including all the details surrounding your thought process and troubleshooting. The truck was pretty badass when you bought it, but it obviously needed your attention to the details to make it right in every way. Props brother, that truck is just sick. Keep up the great work. This serves as motivation to many others!
I did @iamdub. Came out great. Thx again.
Thanks buddy.
After looking at the center I’m going to remove the wrap on the HVAC controls. Especially since a new brushed metal main bezel is coming. Also the new TC button/ power outlet assembly is going to be black. I also have a USB outlet connected to the HU and ready to go that will replace one of the power outlets.
D48ACF19-7CA3-45EC-B45E-BB85DDBD9E47.jpeg 73E8145C-50EE-4711-9A02-D67E0B2DFB54.jpeg
Got some parts in from Ebay today and I’m happy to say they all look like new. I always wonder when buying used parts because sometimes the pics make them
look bad and when you message the sellers they’re not much help. Even the plastic caps on the power outlets look like they’ve never been used. I needed the headlight switch in order to assess if my rocker switches for the bags would fit in the pocket, and I see there’s no way so I ordered the AVS 3-rocker remote. I kinda wanted an excuse to convert to it anyway.
75D5F2DE-C6DC-4208-86B9-84E57E69D93E.jpeg 4FD51EEC-5D22-41E7-B8AB-0A8CCB38E349.jpeg D314AE3D-83B1-4858-A6B1-347FC571A224.jpeg FF04A908-C56F-45F8-9342-A578D26BCB0A.jpeg 49183C31-1DBC-4793-8751-7EA995DB97BE.jpeg
Sam Harris
View attachment 237530 View attachment 237531 View attachment 237532 View attachment 237533 View attachment 237534
Ahhh yeah!
MonteJ
