Gas pump keeps shutting off while filling
Sourdeez
I just got a 2010 SSV Tahoe and both times I filled it up so far the gas pump shuts off every few seconds, I have to keep holding it and clicking it on and off a ton of times its quite annoying. Any ideas what could be causing this? My knowledge of that area of vehicles is completely lacking
Same station and pump? Try different ones. If it keeps happening, you likely have a clog somewhere, clear the vent line first in the filler neck and then the lines that go to the charcoal canister, might be full of charcoal all the way up to the valve on the engine.
S
Sourdeez
two different pumps, in two different states! Any tips on how to do that. I’ve never messed with anything gas tank related
Oh also I noticed on the California pump if I held it up at an angle it seemed to work better if that means anything
It's telling us that your tank is not venting fumes well enough and the pump nozzle is picking that up and clicking off thinking you are full.
You're basically disconnecting hoses and blowing through them to make sure they are clear of obstructions.
You can google for the diagrams or just crawl under and have a look, start with the small line that runs along the filler hose.
akbrener
Baltimore, MD
check out this thread: https://www.tahoeyukonforum.com/threads/conquering-the-nnbs-p0449-code.50935/
I never had a code if I recall, but did have trouble fillng my tahoe. the evap cansiter hose assembly and jumper wire fixed my issue. the new vent part gets relocated up near the top of the fuel filler neck under the truck. I am pretty sure I did this in 2014 and havent had any issues since.
Stache
Had this exact same issue replaced a bunch of parts including the charcoal canaster....this is what fixed mine. Havent had an issue since.
ACDelco 23481275 GM Original Equipment Vapor Canister Vent Valve
I have a 2007 tahoe...this part is connected to the charcoal canaster (big black box)
mattjones
VA
I’ve been noticing this with my 2011 Z71 recently at different gas stations. Pull the nozzle out of the tank a little bit next time you fill up. Not having it inserted all the way in seems to have solved it for me so far.
Mine just started doing this. I can hear the air squealing out of somewhere as the fuel is backing up in the neck. The pitch gets higher as the fuel gurgling gets louder, then the handle clicks off.
Check the vent and see if anti-siphon is still working, if you have it.
Is that the hose that goes up the filler pipe?
As much as it sits, it's probably clogged with a mud dauber nest. lol
I plucked one off the RH exhaust manifold a couple weeks ago.
trailblazer
If you’re cheap, then you can pull the canister and flush it out. A lot of black nastiness will come out. There is a YouTube video of a guy doing this. He flushes it quite well and then uses pressurized air to dry it.
2591tdj
Miss
Your check engine light is not on? Mine threw the p0449 code. I replaced the Purge valve and solenoid on mine and bought a new vapor canister that I will replace when I get my Tahoe back from my son who borrowed it. These are easy replacements that you can do yourself if you need them. The only trick is disconnecting the hose connectors.
I'm cheap and planned on doing something like this if I didn't find anything obvious with the vent hose(s). I'll search YouTube for ideas.
Thanks for the input!
2591tdj
Miss
You may be surprised at how much dirt you find in the canister vent valve solenoid when you clean it. The top comes off easily to access the filter once you have the valve off the vehicle.
muncie21
My 2009 had this issue. Replacing the vent valve (vents fumes through the charcoal cansister) fixed the issue. The part was less than $50 and took me less than an hour to install on a Yukon XL.
You have a part number?
muncie21
ACDelco 19257603 GM Original Equipment Evaporative Emissions Canister Vent Valve Solenoid Jumper Wiring Harness by ACDelco
Ordered both from Amazon for ~$50
BG1988
make sure you put the pen in the hoe correctly more then likely it's not seating correctly... clean the lip of the filler neck
I had that happen before on my first car
or wait for the summer to evaporate the fuel from the canister
briannorris
