lowh07
That looks awesome!!! im not a fan of all the fake wood thats in mine. I like the brushed stainless the vent parts are, thought about seeing if I could match that, or do like you did and match the exterior color
Thanks. I’ve never been a fan of the fake wood... I was going to leave the vents alone initially but thought it might look cleaner all the same color
Geoffsfas10
St. Louis
Was the vinyl difficult to work with? thats kinda holding me back...that and the weird height changes on the door panels were the window switches are...seems like a tricky spot for vinyl
Bigkevschopshop
Northside H-Town
Just an update for anyone considering mods. Pulling that trailer yesterday. 22’ steel floor car hauler with winch. Before with just a tune it was a labor to pull trailer empty. Now much nicer and when loaded drove like it did without MIT and SLP delete. Amazing how 250 bucks paid off in the truck pulling so much better. I have 3.08 and I am almost satisfied with the towing finally. The resonator delete sounds so nice going down the freeway with a load. 2k rpm just hums so nice. So research mods folks. Do good stuff. And win all around for sure. Happy Saturday guys.
Very happy with how the vinyl came out. Still need to do the door trim and maybe steering wheel.
I’m giving my first shot at wrap. I started with the door switch bezel but found the area where it bumps up around the switch to cause me problems. I’m thinking more heat might help idk. It’s a weird shape.
Geoffsfas10
St. Louis
those are the pieces that worry me the most about wrapping with those weird little bumps. appears you did a decent job though
Rocket- a heat gun is best. Hair dryers are not hot enough.
Be careful they will melt plastic.
I used a heat gun but was afraid to get it too hot so I barely hit it. I watched some videos though and I think I need to hit it more. I’m gonna try again.
It’s ok, not perfect. Thanks.
the_tool_man
Upstate South Carolina
How hard is it to remove the dash parts for wrapping? I'm always worried I'll break tabs off the pieces. I was going to buy a second set to wrap. But if it's low risk, I may just try it with the ones I have.
lowh07
a heat gun helps. I used Avery and it seems pretty forgiving
I’ll be doing those today. Maybe more heat and primer if you have problems with it coming loose
Magnetman59
