Dealer not honoring warranty work..2018 5.3 Yukon issues
Status
Not open for further replies.
kbuskill
NE. FL.
Dmitry, are you saying that your catalytic converters are up over 1200 degrees after idling for say 20-30 minutes after the engine has reached temperature?
I have sat in a passenger seat and watched my cats before. Accelerating on the highway they easily climb up to the 1500s and then begin to slowly cool and at around 70 mph settle into the 1200-1300s on level ground. They'll quickly heat up going over a hill (bridge) and then begin to slowly cool down again.
Myself and @kbuskill have talked about cat temps before and posted our findings somewhere on this here forum.
I can't recall the exact temps but if I remember correctly the cats should be somewhere in the 700° range after idling for an extended period of time... I haven't looked at mine in a while and I didn't commit it to memory.
S
smokey_mountain
Just to make sure we are talking about 700 degrees Celsius or Fahrenheit when they are in idle? I did not wait for 20 mins to measure them but when I drive on the even flat surface they are in 1300-1480 F (705-770 degrees Celsius). I will let them idle for 15-20 mins and measure.
I found a correlation that shaking in D at a stop is much worse immediately after driving hard (e.g. on a highway, up the hill) and then coming to a stop while in D. Somehow engine gets much hotter in those driving conditions and that causes distinct rough idle immediately after that. Am I correct that it points more to fuel supply related than ignition related? I read somewhere that ignition issues usually improve as engine get hotter, and fuel is opposite?
Thank you James and Ken for your data on cats!
My pleasure Dmitry. Comments on cats are in fahrenheit. Overall your temps don't seem out of line compared with mine, which is a different generation. However, one side of your engine was hotter than the other when you posted that data log.
kbuskill
NE. FL.
Yes, as James already said... that is 700° F and that is after idling for an extended period of time... if my memory serves me.
S
smokey_mountain
Oh, if 700 F I have never seen this temp when engine is running. I will warm it up and let it idle for 15-20 mins tomorrow. Thank you.
S
smokey_mountain
wjburken
Eastern Iowa
I am trying to fix the issues on my own. @Bob2C had some success with his truck and CRC GDI cleaner. I found a thread on the gm-trucks and they recommend using this line here: https://www.gm-trucks.com/forums/uploads/monthly_03_2016/post-129450-0-16852400-1458543187.jpg
Any advice from anyone on that place to spray CRC GDI Intake Valve Cleaner? Manufacturer on the can recommends vacuum brake booster line to spray into.
I’ve heard of going through the brake booster line but I’m skeptical of how well that gets the cleaner to all the valves that are upstream of where the vacuum line connects to the intake manifold. I have used the Seamfoam product with a throttle body adapter for the can. Here is a link to what that’s all about.
BG1988
checked ascending 2000ft Cat temps ranged from 350C to 680C mostly 550-590C
Decending 2,000 ft air temp 31-33F 140C to 633C @ 50mph quick peak temperature
140C@ 35mph @ 37F
(mostly 140-400C range )
everything was reading 0 values on the cat and fuel trims....etc.. the engine was running and @.35mph... when the cat drop to 140C..
no pending or 131/420/430 code..
just a sloppy guess honestly i kinda surprised as a California certified models have Tighter threshold...
140C@ 35mph @ 37F
Mine has/had California Emissions too.
S
smokey_mountain
I decided to postpone running cat idle measurements as I still have that BG Platinum in the fuel. I know it is snake oil indeed but I am desperate to try about anything as my wife is about to send me to the couch for buying this masterpiece truck for that much money.
Another question when someone sprays CRC it is supposed to be into the open Throttle Body and PCV line with batwing part of the air intake removed and PCV ventilation disconnected, is it supposed to set codes when I disconnect air intake connections, PCV valves and run engine like that?
wjburken
Eastern Iowa
If you have the air intake removed, you will get a code because it’s looking for air flow across your MAF sensor.
Disconnecting your PCV hose will likely cause a code as well as your vacuum levels will be off.
S
smokey_mountain
Asking for more advice if possible. I spent 8 days just driving and trying to document how to re-create the problem. If anyone has any additional thoughts based on the steps described below, please let me know.
GM finally called back saying that they will take another look at my case (it only happened because I have opened BBB Autoline claim, they must respond by their contract with BBB doing mediation.
Here are the steps to re-create the problem + new issue, I am hearing. Just a reminder (this is a very long thread now), 2018 Yukon SLE with 5.3L 4x4 6-speed, 9,200 miles.
1) Truck needs to be driven for 15+ minutes at 40+ MPH to achieve the max. engine working temps
2) After intense driving when come to a full stop while still in Drive, let the engine idle for 15-30 secs and only then it would start to miss.
3) It is not a reqular miss, it is irregular, but happens every 2-5 secs.
4) Observe the Tach needle, it fluctuates, RPMs dip to 480-490 when engine misses.
5) Here is another found problem. When driving uphill in low 1100-1400 RPM 30-40 MPH and accelerate a bit on the driver's side I hear what could be either cyl #7 lifter chatter or exhaust leak sounds, sometimes like metal clunking in the engine.
1) It takes that long to heat up? How about a remote start, is the engine to temp at the end of ten minutes of idling?
4) Dips to 480-490 from what?
5) AFM is probably active and if at 35 or below you're in 5th gear. This is probably at the point where AFM turns on and off regularly, try to stay out of this.
Get the tune to raise the idle, GM will never know. If you test drive another I reckon its idle will be higher than yours.
S
smokey_mountain
Thank you, @swathdiver
1) It takes that long to heat up? How about a remote start, is the engine to temp at the end of ten minutes of idling? [ Good point, I know it is not correlated probably but somehow I am noticing that misses are more obvious after real driving, e.g. especially after highway. I thought for a while if my issue has transmission in the mix, something about transmission warm up... Probably not. I do not have remote on mine but I will start and let it warm up.]
4) Dips to 480-490 from what? [It stays around 500-505. When it misses it dips to 480.]
5) AFM is probably active and if at 35 or below you're in 5th gear. This is probably at the point where AFM turns on and off regularly, try to stay out of this. [This is noise is actually at 40+ MPH clunking is quite obvious when driving uphill without pushing accelerator, kind of lugging the engine maybe in some way].
Get the tune to raise the idle, GM will never know. If you test drive another I reckon its idle will be higher than yours. [ Given my fragile situation with this warranty truck, anything that I do to the truck will be used against me. Blackbear guys said they do a lot to make sure that ECM does not get re-flash mark that GM can see, but they cannot confirm it 100%. Local tuner told me that there is no way to avoid an ECM re-flash mark, no matter what people say. Not sure who is right and who is wrong. ]
1)
If BlackBear's tune was ever detected by GM and it became a problem, we've NEVER heard about it on this and many other forums. I would think that if GM detected their tune, we'd sure know about by now. To each his own though, I get it.
Hmm, maybe you have a torque converter issue, maybe the transmission needs new fluid? This is a common complaint with the 8-speeds and less so with the 6-speeds in the K2s.
Mine varies that much at idle and don't consider it an issue.
S
smokey_mountain
It could be, however according to the Hendrick GMC dealer they were told not to do engine mount replacements anymore as it is an expensive temporary fix. @Bob2C had rough idle come back after engine mount replacement but I think finally his issue resolved itself somehow (which is a terrific news!) but engine mount swap did reduce the problem, but not completely eliminated it for a few weeks if I am not mistaken. He did something right and now the root cause of rough idle is gone and his truck is smooth.
Still sounds like an engine mount issue.
S
smokey_mountain
Finally found a very honest dealer - Medlin GMC in Wilson, NC, highly recommend them. I know they have tried everything that GM told them to try, it was in the shop for 2 days now, they have tried re-programming the truck, did couple more technical notices on the truck. GM now wants me to drive my truck for a few days and see if it made any difference. I am driving to pick it up tonight, wish me luck!
S
smokey_mountain
Dealer did check everything according to the work order:
  • Engine mounts with picoscope
  • Misfires cold and hot they said they see zero misfires on their equipment
  • Injectors via afit test are all within 15% of each other
  • Lugging/engine noise on the acceleration, not heard
Conclusion was - cannot reproduce any of my complaints. Truck is within GM specs. Advisor genuinely felt there is nothing that can do. Service manager was very accommodating and friendly but there is nothing that they can do.
I drove it for several hours since the pickup, absolutely no change, still misses as before, $06 monitor still shows misfires on cyl 7, cyl 6, cyl 4, cyl 3, cyl 1. Engine still makes noise on the acceleration up the hill in higher gear.
I think dealer did everything that they could without spending their own money. I respect them for that. I will take it on the longer drive this weekend and then if all the same - Nissan Armada is no longer as ugly as it was 3 months ago when I was buying this Yukon :) I will be crying at the pump but and when cruising at 70 mph. Yukon is just that super-plush.
Status
Drewphil
