Kee Fuller
Spent like an hour trying to remove the boots to change my spark plugs. I gave up and ordering a boot puller.
I did the same... replaced everything with LED's...
Everyone is doing it wrong taking apart the whole car to change out the bulbs
I found a simple solution that only requires 2 parts removed from the engine bay and child slave labor
as those little tiny hands can get into small space![]()
Spill it! I couldn't even get the headlights out. Previous owner or dealer broke a headlight bracket trying before it seems.
If you’re referring to the DRL’s, pull the non-working bulb, and flip it 180 degrees. Some are polarity sensitive, so only work one way.Got a link or pn for what you used? Got both bulbs changed out and only one lights. Probably because I banged that shit around trying to get it back in lol.
I've had a set of Craftsman bolt extractor sockets for maybe 10 years. They came in a red case and have worked the few times I've had to use them.
All you need is some harbor freight pliers like these, just grab the boot firmly and yank
Those pliers are like 20 years old btw, lol one of the few things that has lasted from there, my heat gun from there that had maybe 15 minutes on it died the other day the fan crept up to ludicrous speed and then imploded in a sparkly smokey death haha, had to get the wifes hair dryer out to finish shrinking some heat shrinkAnother tool for Santa's list.![]()
I’ve had one of their heat guns for years, still going strong. I think some stuff is hit or miss.Those pliers are like 20 years old btw, lol one of the few things that has lasted from there, my heat gun from there that had maybe 15 minutes on it died the other day the fan crept up to ludicrous speed and then imploded in a sparkly smokey death haha, had to get the wifes hair dryer out to finish shrinking some heat shrink
ya I have had mine for quit a while but it was barely used, I suspect that the last time I used it I kinda tossed it in my tool box a little too hard and it probably broke something inside.I’ve had one of their heat guns for years, still going strong. I think some stuff is hit or miss.
More than likely you just have the non working bulb in backwards... led bulbs have polarity and will only work installed one way... ask me how I know this...pop it out and flip it around and stick it back in... should work then...Got a link or pn for what you used? Got both bulbs changed out and only one lights. Probably because I banged that shit around trying to get it back in lol.
Just got some 45 degree needle nose pliers from walmart. Gonna try again tomorrow
Great song.The trick is to get down in the hole and try to pull the boot off by hooking the end of it. Pulling on it makes it act like a Chinese finger trap. Twist it first to "break the seal". I recall years ago having some that were really stuck. I used the Harbor Freight angled-tip long needle-nosed pliers and cut the tip down so it fit down in the hole.
Trying to imagine this in my head. Lol
