This weekends work...
PPV12HOE
PPV12HOE
NC
Anybody need a cruise control harness...?
PPV12HOE
PPV12HOE
NC
I'd like to beat a designer and engineer to death... I'd love for just once these retards would have to work on the stuff they design... #8 plug is a pita...
PPV12HOE
PPV12HOE
NC
Forgot to bring the hot knife home from work so the cabin filter will have wait til tomorrow and other means...
PPV12HOE
PPV12HOE
NC
Cabin air filter installed... why do they give you a 1/4 inch headed screw in the kit when all the rest of the screws in the truck are metric...
wjburken
Eastern Iowa
That baffles me as well.
I’ve scolded engineers that work for me when they use both metric and SAE hardware on a machine. The best is when a young engineer calls for a tapped hole on a round spacer for a M6 bolt (10mm wrench) and then put 3/8” wrench flats on the spacer.
PPV12HOE
PPV12HOE
NC
Next time I'm at the junkyard I'm gonna grab a different screw that matches... otherwise it will drive me nuts...
HiHoeSilver
Away!
Chicago
That's usually about the time I start throwing things.
1BADI5
DMV
More information on this cabin filter retrofit? Thanks!
I have ole #8 down to a 10 minute process plug and wire
PPV12HOE
PPV12HOE
NC
It's super simple with the right tools... which I left at work and had to improvise...
Order a retrofit kit. Basically it's a filter and a cover and screw. Remove lower cover. On the underside between the fan and evaporator you will see a space made for the filter to go in. Cut out along the line. Just go slow and easy. Hot knife would work extremely well here. Then it's just a matter of sliding the filter in and putting in the new filter cover. Then put your lower cover on and your all set.
PPV12HOE
PPV12HOE
NC
So this came in the mail today... looks like a trip to the store is in order... need some hose and some threadlocker...
1BADI5
DMV
I got the one from UDR.
Catch cans are a must have
Sofi09
I just got mine too but haven’t had a chance to install looking forward to your write up and parts list [emoji1303]
varminpoolteam
