2013 Tahoe, front part of dash
Ron C
Los Alamos, NM
Hello,
the front part of the dash, nearest to the windshield, finally cracked.. somewhat ugly, near the VIN number.
Is the an after market one, black, that it can be replaced with (and doesn't crack that asy?)
Also, does anyone know the original part number?
(I have been thinking about maybe have that "shell" installed, that covers the whole dash. any pointers for that?)
thanks,
Ron
Unfortunately, I cannot help you out directly with your question; however, I know that this topic has been discussed extensively on this Forum. If you have not already done so, perform a search on this Forum for dashboard cracks.
Ilikemtb999
Denver
The front piece as far as I know doesn’t get covered with the dash covers, at least mine doesn’t. I just pulled mine last week and repaired the cracks with a plastic welder. Every clip was broken off and the drivers corner was cracked off. It looks alright but certainly not as good as new. The biggest problem is just how cracked the dash is under that piece.
they’re under any gm parts store. Look under instrument panel. They’re not cheap and don’t see it lasting with the dash being messed up underneath.
PPV12HOE
NC
Ron,
You might want to talk to @kylers2k I think he put in one of the slip-on covers on his dash...
Kyle
Ron C
Ron C
Los Alamos, NM
Hi Joel,
Yeah, we had our first snow/frost here in the mnts, in NM, we had snow in the morning, it melted, then froze again over night, and during the day sitting in cold weather, in the baking sun. I think the material the dash is made out of realy doesn't like temp changes. (the corner near the VIN number isn't just cracked, it shattered into 4 pieces, no real way to fix it I think.
The front part is cracked, near the airbag.
I might replace the "front part with the defroster duct, and put a cover on the larger/inside part. How easy is it to put a cover/shell on there? does it look at least good?
thanks,
Ron
Ilikemtb999
Denver
I just worked piece by piece to get it back together after seeing the price of a new one. It indeed is brittle but I no longer have a terrible rattle.
Putting the cap on isn’t bad. It didn’t 100% fit the contour around the top of the gauges so I had to warm it up some. I used regular silicone to install. I don’t know what brand it is because it came with my vehicle.
Dashmat makes covers they are only $40, you can choose from several colors and you can custom embroider one also if you want, they have been around decades
kylers2k
NC
I did the dashskin cover and it's great quality. Right under $150 shipped. No one notices it riding with me unless I point it out.
Ron C
Ron C
Los Alamos, NM
Hi there Joel,
I bought a used/salvaged one that was in a really good shape, still $160, but a new one is twice that. I am also installing an XM antenna in a "pre-owned antenna hole" and want to route it underneath that panel and drop it between the two air ducts. I'll install the panel after that. I want to keep the old pieces, there seems to be a shell for the front too.
as I said, I really like my Tahoe, but the black recycled panels are junk, it seems. Who would have thought that recycling plastic, (re-heating it so it can be moulded will break polymeres) and setting in in the baking sun at 20 degrees would be asking for trouble.
Ron
Ron C
Ron C
Los Alamos, NM
gm#23224733 ebony in coloer
$361.80
googled the # saw a few on ebay for under $100
I didn't see them on ebay that inexpensive, I found one in a good shape that was $160. I was/am seriously thinking if I should put a layer of JB-weld on the underside.. but ... that might get pretty expensive.
Ron
Hi Wes,
I am the guy that replaced the dead audio controls with a $40 cubby *lol*.. I'm not gonna put carpet on the dash.... :)
Ron
I was just suggesting alternatives to "glue-ing" a cover on, a new replacement dash is the best fix but a bit costly
veteran111
