R3cord303
Posse In Effect
Oregon Valley
Update (sorry no pics) for you all. That "coil whine" sound I've been having that I thought was either my head unit or Bose amp- I found out that the noise goes away when I turn the HVAC off! So I'm hopeful that its just worn bearings in the fan motor. I'm going to get a replacement blower from somewhere. I'd like to get an OEM one but will see. Depends on price I think. Hopefully it will go away once that's replaced.
R3cord303
Posse In Effect
Oregon Valley
I would love to add similar LEDs to the grill kinda like the "Raptor style" grills like you see on 4Runners. Kinda like this
My Jeep buddy that kinda prompted this has the same lights but in amber, which he ordered by accident. In the video he sent me, they still are plenty bright and would definitely work in a grille. At ~$10 for a pack of 6-10, why not?
R3cord303
Posse In Effect
Oregon Valley
Gotta figure out a way to mount them. The same JB Weld I use after I cut off the intake tube resonators?
wjburken
Eastern Iowa
Do you have Auto A/C? If so it could be the aspirator in the ceiling above the drivers seat.
Does it change pitch with fan speed and go away completely when you turn the fan off? You just mentioned turning the HVAC off but turning the fan itself off will narrow it down.
R3cord303
Posse In Effect
Oregon Valley
Nah i’ve already disabled that thing. Bearings in that fan are destroied.
It does go away when turned off, and doesn’t change pitch so much as it just makes a slightly different pattern of noises at different speeds
What do you mean you disabled the adpirator? It’s kinda important even if you don’t use auto.
CHOO CHOO
BackPagePhil
Manheim, Pa
Came home from being gone for 2 weeks. Battery was completely dead, couldn't even jump it. Wasnt even a year old.
That sucks dude.
You’re the second guy here that came home from vacation to a bum battery. @CHOO CHOO had the same thing happen to him recently.
Exactly the same. Ended up buying a new battery.
Advance Auto gold battery was $135 with a 25% off online coupon and core charge refunded.
I thought it’s part of the interior temp sensing. :popcorn:
I mean, it IS the interior ambient temp sensor....the fan is there to pull air across the sensor. I’m not sure what the vehicle uses for interior temp when you remove that but I guess if yours still works, great. Probably not as accurate IMO. I am in the habit of fixing stuff not tearing it out. :)
R3cord303
Posse In Effect
Oregon Valley
It doesn’t need to sense the temp if its not in auto mode though.
Don’t you set a temp? Or does yours not maintain a set temperature? That’s what it’s for. It doesn’t necessarily have to be in auto mode to need to know what the cabin temp is. I don’t have any vehicles without at least temp settings. IDK, I leave mine on auto and the only thing I do myself is change the blend setting. I never touch fan or temp. I guess I could leave it on full auto but I like just a little control.
R3cord303
Posse In Effect
Oregon Valley
Not sure. I set a number but i mean I dont have a freezer thermometer sitting in the console to know what cabin temp is. I always figured ‘60’ was all the way in the blue on old style HVAC controls and ‘90’ was all the way in the red. The change in the sun going behind the clouds will effect how hot it feels in the cabin more than it will the outside air temp changing 3 degrees.
TejasPitt
