Steel rim bead seat
Woodblocker55
I just clear coated my steel rims .
Clear coat some pretty tuff stuff ( sanded it alot ) . I was thinking on putting extra coat on the inside lip of rim right where the tire bead seals on . To stop rust from gathering there . Has anyone tried this ? After sanding clear coat it made me think it be alot harder then just paint in that area and extra coat there help out .
Sent from my LGL84VL using Tapatalk
Matthew Jeschke
Sahuarita, Arizona
Bit unrelated question, which steel rims do you have? I have wanted to get a set myself.
Sent from my SM-G925V using Tapatalk
Woodblocker55
Woodblocker55
It's 16 inch spare I'm putting 10 ply winter tires on .
Woodblocker55
Woodblocker55
Anyone know the max PSI of these rims can handle let me know . One place says 100 psi other said 80 psi and I can't find it on rim .. might be rusted where numbers are and I never know .
Scottydoggs
NJ
they came out nice...id not worry so much about the air pressure, fill as the tire is rated. 80 psi is a harsh ride tho. i run my tires at 40.
as far as the inside of the beads, sand em clean of any rust and crud and i'd do just a coat or 2 of paint should seal em up good.
Woodblocker55
Woodblocker55
Putting them 10 ply tires on the rim is something else there super tight going on I got bunch chips and scratch's to deal with . Ya commercial 10 ply tires are pretty much a perfect rims enemy. That bead barely goes on . There super stiff tire . You couldn't have enough soap lube on everything .
235 85 16 on a 6.5 inch steel rim .
I put some 14 ply trailer tires on a 7 inch rims and they were a breeze getting them on rim you could push first side on by hand with alot soap . d94900a280c80ea26145076f45a687ad.jpg
Woodblocker55
Woodblocker55
They sealed good we'll see if any leaking in near future I have 40psi in now 235 85 16 it's still pretty harsh ride empty ..could I go down to 35psi ? 10 ply it corners and rides way nicer on tar roads . Steers way easyer. Then the 265 70 17s it kinda gives it the look of cross between GMC Yukon XL SLT crossed with Chev Work truck . [emoji106] 4:10 gears kinda likes them . Height is 31.7 inch I measure them . It's a shocker how good it handles .
Scottydoggs
NJ
those 10 ply tires, they got a super stiff side wall. why it handles and turns better. and rides so much stiffer.
make sure you rotate them every 5k to get the most life out of em.
Woodblocker55
Woodblocker55
I think these thin tires will work great in The snow and ice . [emoji106]
Scottydoggs
NJ
i used to snow plow with 12.5 wide 33 inch tall BFG's. in 2wd 80% of the time too with my 03 gmc 2500 HD pick up. never got stuck, other then when i got my self high sided hard core. not a wheel touching the pavement lol
ive heard the skinny wheels work better for decades now. more weight to a smaller contact area. but im not buying that noise for the last 20 years. funny how i was always pulling out the fords with their fake 4wd set ups. right rear and left front is not a 4x4. i had a locker and damn good limited slip up front. hit the pile and spin the wheels and i'd leave 4 black spots where the tires spun. you'd see the snow kick up past the fenders on both sides too. i miss that damn truck. was a real beast.
Thekenstar
