kbuskill
NE. FL.
New ground cable with sensor in the last 6 month, both battery's are less than 2yrs old (odyssey extreme agm's 34/78), big 3 upgrade, plus a new nbs style positive cable direct from alternator to 2nd battery, I do loose about .2 amps from alternator to battery I get like 13.78 testing alternator direct to ground bracket, then I get 13.58 at either battery
when I was testing it yesterday I (think) it was showing fuel economy mode-active when the voltage was down to 11.3v, which it should not have been active as far as I can gather which is making me lean towards a firmware issue. There is a bit of technicality to how the rvc system works like how much battery charge it shows, what the battery temp is estimated at etc, etc.
Strange... Didn't you say you unplugged the RVC sensor and it didn't make any real difference. Seems like unplugging it would make it go to a pre set/default charge mode.
Keep is posted on what you figure out... its definitely strange.
It didn't at first with everything going full bore, after a couple restarts and a little break it started giving 13.8-14, I tested it again this morning with the rvc sensor still unplugged and voltage was running normal 13.8v, fuel economy mode was off, battery was reading 14+v. I am going to take it for a little drive here in a bit and see what it does
kbuskill
NE. FL.
Do you think it is heat related???
In other words, when it's cold does it seem to charge better and once it's up to temperature, like after driving for a while, does it seem to charge less?
Tested the control functions of the ALC system.
Snipped the wires to the locked-up compressor and stabbed in my DVOM leads:
Jumpered the blown fuse instead of using the $5 replacement I bought yesterday as a Guinea pig:
Disconnected and propped up the height sensors with some wrenches to simulate a sagging rear end:
I wasn't sure if it'd activate the compressor with just the key on so I started it. After a few seconds, the DVOM went from "0" to 14.xx VDC. I removed the wrench on the driver's side and slowly lowered the sensor arm and the DVOM went to "0". Lifted the arm again and held it and the DVOM went back to 14.xx VDC.
Best I can tell, the system is ready for the new compressor! It was supposed to be delivered today but I doubt that'll happen because of the storm. Oh well, at least I have some diagnostics out of the way.
kbuskill
NE. FL.
There seems to be some kind of time delay built into the system. I noticed this when I was adjusting my level sensors after lowering. You move the sensors and it takes several seconds before the compressor kicks on or the exhaust valve opens.
If I ever do the TBSS bags I plan on hooking up a switch to the exhaust valve so I can have the option to dump it when I park if I choose to.
Good work. How are you holding up down there?
There has to be some kind of delay in response, otherwise the compressor would kick on every time you hit a dip and the suspension compressed. I figured out that there was a delay of at least 5 seconds after starting it cuz I had 5+ seconds of suspense and disappointment after I cranked it up. I moved the sensor arm very slowly and paused ever so often while I watched the DVOM until I was satisfied that it was responding as it should.
Oh- The factory air line actually fits a little loosely inside the Air Lift line, but the flared end is kinda tight and should be plenty sufficient for testing with a clamp on it. If it all works as planned and I'm ready to make it permanent, that size difference will be convenient in allowing space for a healthy packing of epoxy.
Short of the compressor's performance with the bags, I'm optimistic. Soon enough, I should be able to give you an idea of how the compressor will do so you'll know if you could pump up the deflated TBSS bags within a reasonable time frame.
Thank you.
I'm actually really enjoying the weather! I had breakfast and was on the patio with coffee and laptop for 8AM just so I could enjoy the 75° temp and steady 20MPH breeze! Had a few spotty and light showers that were more like a sideways mist because of the wind but now it's a steady light rain. It's only gonna get worse from here. I'm not expecting anything detrimental at all, just stiff gusts and lots of rain.
The cooler temp is why I'm staying out here tinkering. I was even gonna do the trimming for the Belltech alignment cams but realized I'd need the strut outta the way, so I just took notes and put the wheel back on.
Realized the mesh of the grill could be popped out so I grabbed a plastic trim tool and made quick work of that to get an idea of how a black grille would look:
I may spray the removed pieces the same black that I paint the wheels (satin/low-gloss) or just trade someone my chrome for their factory black ones. I think I'd prefer that chrome outer ring to be black as well instead of color-matched. I have some aluminum expanded metal that's similar to stucco mesh. I may use the pieces I took out as a mold and make my own aluminum inserts, because racetruck and boredom.
In other words, when it's cold does it seem to charge better and once it's up to temperature,like after driving for a while, does it seem to charge less?
well something is up, left the sensor unplugged,I just went for a drive voltage was good 14+, until I exited the freeway, with 1 seat cooler running, headlights, a/c front rear voltage dropped down to 11.8v sitting at the light on the offramp, went to the post office left it running it sat pretty much right on 12v idling, then on the freeway back it went back up to 14+.
so just to rule it out I am going to pull both battery's and have them load tested and go from there. it is 93deg
Pulled both battery's, drove all the away across town to find the shop I bought them from closed at 3pm, , so in the meantime I put the original ac Delco standard battery back in and hooked everything up including the rvc sensor, started it up turned everything on and same results, 11v and the dam fuel economy mode is still active, couldn't be heat related to the battery.
Lemme "grill" y'all for a minute...
I dug out two candidates for "custom" grilles. I still may not use either of these and may pick up a sheet of stucco mesh since it's easier to work with. Whichever I use, it'll be painted satin black and recessed deep. I'll make two small matching ones to go in the tow hook holes. I think I know which one I like best, but the other gives me doubts. They're not such a concern, but I listed the stats for fun. What y'all think?
Contestant #1. Perforated mild steel, 1/16" thick, 1/2" holes on 11/16 centers, 48% open area:
Contestant #2. Aluminum, 1/2" #16 flattened expanded, 64% open area:
I vote #1.
Hey Wes, your battery temp is reading in Celsius for some reason, 55 degrees celsius is 131 degrees fahrenheit. Mine stopped charging the other day when the battery temperature got just shy of 110 degrees and it was about 99-100 out on the highway. My battery is an ACDelco 48PS and is 35 months old now. The shop manual says to not charge the battery if the temperature climbs past 45 degrees celsius or 125 degrees fahrenheit. I've been looking for a half hour and don't see anything else about it.
Crawled under the truck today to look at some wiring and saw that the rear of the transfer case and front of the driveshaft was a little wet and that the front of the rear differential was also a little wet. So it looks like the seals need replacing on both. Need to get her up in the air a little to check the fluid levels, maybe tomorrow.
I think the firmware is goofy that battery was under the hood for about 30 minutes and had not even been ran for even 5 minutes when I took that reading, it was about 95deg today so I guess anything is possible, I will take another reading tonight after it cools down and see if it changes anything
worleytrev93
