And you’re partly responsible for my decision [emoji106][emoji16]American Racing longtubes with or without their high flow cats ftw.
Only partly?And you’re partly responsible for my decision [emoji106][emoji16]
And sending one snail mail is the slowest way ever to pay someone. Gives you lots of time to change one’s mind and stop payment. Love it.Had to Google "check". *sigh* You're one of THOSE.
I guess you holding up the line at the grocery store as you fill out your check is still way faster than you counting out your change to the cashier.
Check’s in the mail.![]()
Better to owe it to you than cheat you out of itNot buyin' it. I've heard this from you before.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
+10 HP=pricelessThat's true. But to be clear, he doesn't owe me. If anything, I owe him because of the extra hp provided by the red catch can in my engine bay.
[emoji16][emoji106] mostly...Only partly?
+10 HP=priceless
Will they really yield that much horsepower?
Mines done the same since I had it installed 8 years ago. Never caused a problem and went away immediately. Wish I had a better answer, just wanted to give my experience.So three or so weeks ago I installed a McGaughy's 2/3-4 drop.
Since the install, I've had an issue of intermittent low speed ABS activation while turning sharply. If I'm on the brakes, the ABS pulses, if I'm not then just the traction control light flashes.
So, obviously a wheel or two is not reporting speed correctly making the system think either a wheel is locking up, or losing traction.
I was out of town for a couple of weeks with work, so in the last few days finally got a chance to circle back on this. I replaced all four wheel speed/abs sensors. No change. Exactly the same behavior. I'm at a bit of a loss now. On the drop spindles on the front, with how where the hub/wheel bearing is located, the sensor is a bit of a tight fit between the spindle and hub, but it's fully seated.
The front wheel bearings/hubs are fairly new (less than a year) Timken units. The only thing I can think of now is that when removing the sensors out of the wheel bearings/hubs while installing the drop spindles some trash or debris got down into one of them and maybe that's causing a funky reading/signal? When I put the new sensors on, I rotated the hubs 360* while looking down inside and they both looked clean.
I'm tempted to just throw a couple of new front wheel bearings/hubs on it and keep the current ones as backups, but I'm open to any other thoughts, ideas, or suggestions before I just throw parts at it.
I don't think any of the generic scan tools have the ability, but is there a scan tool out there that has the ability to log or read all four wheel speed sensors? That might assist me in targeting which corner is the culprit.
TECH2 will tell which sensor/hub is going goofy, a standard scanner that does abs might tell you, but like chris said check the rear abs connectors they are dead center above the rear top shock bolt locationSo three or so weeks ago I installed a McGaughy's 2/3-4 drop.
I still get the abs on a tight turn sometimes. More like if it's a tight turn on an uneven surface. It's weird, I've never really tried to pinpoint it, but the uneven or elevated ground while making a sharp turn usually makes it happen for me. Hope that makes sense.I'm well aware of the fragile rear ABS sensor connectors, not the issue. One of the first things I tried with the original sensors. And since have replaced the rear sensors, again ensuring solid, seated connection.
I feel like it has something to do with the front.
@CHOO CHOO - So, you had the same/similar issue after installing drop spindles but at least for you it eventually just went away on it's on?
Like turning into a driveway that has those dips for drainage right as you enter the driveway. My old driveway was on a steep incline, so when I would turn into it, that's when it would come on, then go away as soon as it straightened out.
I wonder if the McG spindles change the scrub radius and it causes the wheels to exceed the allowable difference. If so, I wonder if this can be mitigated by dialing in a little more (negative?) caster, or ensuring both sides are set equally. Is there any Ackerman built into the alignment specs on these things? Aftermarket spindles could throw that off. Although, I thought the big deal with McG's spindles is that they maintained the factory articulations.
