That's a nice switch--should blend right in. Where you gonna put it?
Yes, completely forgot about the pre 02. Would it matter if his is a late 02? Meaning he might have the new for 03 electrical setup. That switch goes where the 4wd buttons would go, correct?
This is what I'm going to use.
2 wires go to both of the fold motors (in/out)
1 power
2 grounds
Already tested it with the front window switch, but to bulky to mount. So I'll be using the rear window switch which is flat and will sit flush.
I’m over here like ‘took off my dl3 mirrors and replaced them with base model obs mirrors’.![]()
Have a link?i just ordered the mirror cavity's to reuse the stock connector. will be a plug and play after i pin the wires in the new cavity.
i really don't want to cut the harness off the mirror just in case i ever go back.
let me do it first and maybe i'll share the link with you TonyrodzHave a link?
YupI just noticed this on a ppv: View attachment 222594
140 speedo. Just curious--if I got the 140 speedo overlay, I'm assuming the speedo would need to be calibrated to function correctly?
Just gotta find an overlay for my Esky cluster.
Interesting. One could make those leds amber or white instead of red....hmmmMy new turn signal mirrors don't move up or down. Looks like the plastic gear is broken.View attachment 222780
Tried swapping parts with a spare mirror, but that one was broken too. Here's the turn signal mirror apart.View attachment 222781 View attachment 222782
Do it!Interesting. One could make those leds amber or white instead of red....hmmm
Yes! Amber would be sweet. Or blue... [emoji16]Interesting. One could make those leds amber or white instead of red....hmmm
Sucketh..My new turn signal mirrors don't move up or down. Looks like the plastic gear is broken.View attachment 222780
Hope it lasts a while.I finally swapped out my damaged handle for a good one.View attachment 222779
I don't think it'll last long tho. New one looks a little weak.
I hope so too. I remove it alot tho--I'm always messing with it, taking the door panel off and on.Hope it lasts a while.
