Tonyrodz's Tahoe Build Thread
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
That's a nice switch--should blend right in. Where you gonna put it?
Not to sure it it will fit, if not will put it where the chubby hole is at next to radio, I'll just have to find the dead plates from the junkyard and replace it.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Yes, completely forgot about the pre 02. Would it matter if his is a late 02? Meaning he might have the new for 03 electrical setup. That switch goes where the 4wd buttons would go, correct?
Yyyyup.... which is why I abandoned the idea. Ours isn't 4wd, but it has an eletronic traction control button in the spot where the 4x4 controls would go. Not giving up ETC when we're moving to a place where it snows and is prone to icy roads.
This is what I'm going to use.
2 wires go to both of the fold motors (in/out)
1 power
2 grounds
Already tested it with the front window switch, but to bulky to mount. So I'll be using the rear window switch which is flat and will sit flush.
....but this give me hope!
915_Tahoe
HELL PASO, TX
i just ordered the mirror cavity's to reuse the stock connector. will be a plug and play after i pin the wires in the new cavity.
i really don't want to cut the harness off the mirror just in case i ever go back.
Have a link?
915_Tahoe
HELL PASO, TX
CAVITY https://www.mouser.com/ProductDetail/829-12047886
LOCK https://www.mouser.com/ProductDetail/829-12045689
CONNECTOR https://www.mouser.com/ProductDetail/829-12047767
i only ordered the 2 cavity's and 4 locks's. I will try to use the wire connectors from the new mirror and pin in to the cavity so i can just plug into the mirror harness. i will also be making a separate pigtail connector for the turn signal and power fold option, so if i need to remove the mirror just unplug two mirror connectors.
My new turn signal mirrors don't move up or down. Looks like the plastic gear is broken.
Tried swapping parts with a spare mirror, but that one was broken too. Here's the turn signal mirror apart.
05Single
afraid of the dark
Hodmjstone
