Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
67RS427
Planning on re-doing my front end suspension, should I go AC Delco or there is much better aftermarket solution?
I used OEM for most of my components, Moog or AC Delco. Other suspension however you have options... I'm installing these this week. QA1 Double adjustable shocks with Hyperco coils.
Chrismnj
Chrismnj
NJ
that might bit too nice for my use lol, about 4 years ago I have installed 4" SST lift kit, believe they utilize blocks on OEM struts, this being said it would be a time to do it right now along with other “bunch of parts”
Sam Harris
Front Sway Bar Links
Front Lower Ball Joints
Front Outer and Inner Tie Rods
Pitman Arm
Idler Arm Bracket
Idler Arm
Front Wheel Bearings
Ball Joints
Just finished 4 of those items on my list. Lol.
kbuskill
NE. FL.
Front Outer and
(Inner Tie Rods
Pitman Arm
Idler Arm Bracket
Idler Arm)
Ball Joints
Just FYI... The half ton GMT900s don't have any of the items in parentheses due to having rack & pinion steering.
Chrismnj
Chrismnj
NJ
Maybe was looking at the wrong year/trim
Chrismnj
Chrismnj
NJ
Have that annoying front end clunk once in a while, hopefully that would take care of that.
Chrismnj
Chrismnj
NJ
Dropping my truck to the shop. Front end work so far, will have them install new tires, since it's a 2012 guess is a time to do TPMS. Anything else you guys would recommend?
EDIT
+ Moog K160098 Shock Mount
+ MOOG K160311 Coil Spring Seat
+ Coil Spring Seat Front Upper MOOG K160310
+ Suspension Control Arm Bushing Kit Front Upper MOOG K6688
01FormulaTA
they are overcharging you for a some of those parts....didnt check the price of all the parts but off the top of my head...
4 GM TPMS (part 13586335) are about $50...$260 should buy about 16-20 sensors
2 Moog Upper Control Arms (RK80669 & RK80670) with Ball Joints already installed go for $70 ($35 each)
2 Moog Lower Ball (K6541) Joints go for $20 ($10 each)
Chrismnj
Chrismnj
NJ
Yeah I know about the slight overcharges, made a deal with guys at the shop on something
67RS427
Slight overcharge is an understatement... The work quoted there should be 75% less than what's shown. Not sure why you're paying for TPMS anyways, most shops near me replace them for free when you mount and balance a tire, it's pretty standard practice. Discount Tire, Belle Tire and most others are included in the mount/balance price and if not they are only $50 for a set of 4... No reason for the ball joints to cost that much either, as someone else mentioned you can get a brand new control arm with them installed way cheaper. The only thing that is normal I'd say is the alignment, the rest is a rip off. I paid $18/tire to mount and balance my summer tires today and that included new sensors, $180 is way too much. Mine came out to $180 and that included $80 for winter tire storage and $50 for a new tire replacement under road hazard coverage.
Chrismnj
Chrismnj
NJ
According to USA Today New Jersey is on 5th place of the most expensive states to live in, and if it wasn't for Camden we would be on 1st, with all seriousness made undisclosed deal with the shop, so they spread the cost of other work between these line items.
St. Louis
Shady, under the table type of stuff..... Lol
[emoji41]
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
I was gonna say--it's in NJ.
08grey
EDIT
Alignment $150
Tpms$260
They saw you comming.
Sent from my SM-G973U1 using Tapatalk
Chrismnj
Chrismnj
NJ
Guys would like to thank each and every one of you for help on this project not going to go by name simple because don't want to miss anyone but again huge thank you! (I am not done yet)
Drewphil
