Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
67RS427
They have laminated the print out, is this any better?
Much better... Surprised it made close to its peak torque so low, not bad for a stocker. You'll see 150hp at the wheels I'm sure with the blower and cam if not more depending on supporting mods. Maybe close to 200hp since you're doing headers and exhaust. Which heads are you running?
Chrismnj
Chrismnj
NJ
Kooks headers, the guy at the shop mentioned that cats may get clogged up.
bottomline2000
Dallas, TX
I rigged up an exhaust pressure tester and my cats haven't gotten cooked yet. Have dynatech longtubes and catted y pipe. I'd imagine a hot tune could do that, but I don't think BB tunes are that aggressive.. I think Kooks green cats are made to survive agressive tunes..
Sent from my SAMSUNG-SM-G900A using Tapatalk
Chrismnj
Chrismnj
NJ
Getting ready to install ABS fuse brake disconnect switch in the cabin, which will require me to pull out the top portion of the fuse box under the hood. Will this cause any problems with the computer or any other truck electronics? That will require a trip to the dealer for programming?
67RS427
Should be fine as long as you unhook the battery first obviously... I wish I had your motivation lol. I just run mine with no ABS fuse so Stabilitrack and traction control are never a problem. It drives great in the winter, no electronics needed.
bottomline2000
Dallas, TX
Wow, u guys have to lose abs to turn your traction control off? Early NBS truk have a switch to disable it..
griffey_mojo
