08grey
Family road trip coming up so doing some cursory checks around the Suburban.
Noticed this difference in the 2 front tires. Seems like a bit more wear on the outside tread of the passenger front than the driver front.
Passenger front tire viewed from the rear.
Drivers tire viewed from the front.
Rear tires look usual. I notice all the Bridgestones seem to wear down on that outside tread, but having one a bit more than the other seems odd. Tires at 32k.
Figured it might be a good run to the shop for a rotate, balance and alignment check before the trip?
Thoughts?
upper control arm out of camber
St. Louis
It was -6 here yesterday morning, with windchill it was even colder. Not quite as cold today, only 5 this morning and currently 19.
It's supposed to get up to 65 Saturday! Crazy!!
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
08grey
This AM
Sent from my SM-G960U1 using Tapatalk
2001 Yukon SLT
Def MOTHER nature--cuz she's CRAY CRAY!
08grey
It's a newer model one. Once you put it in it automatically pops up. I have never had it flashed to the truck. Not sure I'd it will go away when I do.
08grey
Get a set of bolts. They like to break when you try to loosen or tighten them. Rock auto sells them for shorts.
Drok
Cold place in the north
Guess I deleted the pic after i shared it with my buddy. But it was -12 here this am and didnt get over 14 and now back down to 6 with wind chill making it -6 haha.
qcon
Huntsville, AL
Added a flash module to the center brake light. It fires 4 fast strobes then goes solid and doesn't reset if you let off the brake and repress within a couple seconds so you're not always strobing in traffic. It has 3 speed settings so you can run slower flashes with incandescent lamps. Not bad for $20 on Amazon.
JML07denali
Dropped $1,300 on the rear main seal today. [emoji2961][emoji2961]
St. Louis
Is that set to fastest in the video? Almost looks like a loose wire or bulb or something. Do they have them to make all 3 (left, right, center) brake lights strobe?
2001 Yukon SLT
kbuskill
NE. FL.
2001 Yukon SLT
Nope...
LOL
Seriously though... you can add those modules to any of the brake lights you want to.
The bulbs I used in my tails have the flash sequence built into them.
Hi-psi
Atlanta, GA
Other difference I see also is that it says "Rear" for activating the rear HVAC controls as opposed to the earlier ones that said "Aux".
09 L9H
not a boomer
Upstate SC
Finally put in my Airaid Jr. yesterday afternoon. Didn't buy it for the sound, but it is noticeably louder than stock. There's also a resonance at about 2100-2200 RPM, and another at around 3300 RPM. Hopefully will get BBP to tune my truck in Atlanta, but there's no official announcement yet.
ASG-MikeS
