Oil Filters
Derick
Indy Suburbs
I like the KN HP-2011 as well. The well that the filter goes in, while convenient, if the filter gets tight its a PITA to get off. few bucks more, but with supertech synthetic oil, youre looking at a ~35 dollar oil change. So, not breaking the bank.
inmypassatlife
Jim Clifford
Phoenix, AZ
What's a good oil filter for a 2011 Tahoe? Thanks.
I have come to believe that any filter that isn't named Fram is a good Filter. Fram used to be the standard for excellence, now it is the standard for awful. I prefer Wix and NAPA brand
Meccanoble
Georgia
Used AC Delco all my life with this tahoe. I used a Mobil 1 High Performance / High Mileage filter that costs way more than the AC Delco and coincidentally, my oil sending unit went bad afterwards causing my gauge to not function. I find it hard to believe that that alone caused my issue but sometimes our cars talk to us in ways they hope we can understand.
Miami-Dade
Moderator Supporting Member
I have used only AC Delco filters on all my GM vehicles [Cadillac,Impala,Caprice, and GTO] forever. Not changing to a different filter for the Tahoe.
I like the long K&N with the nut on the end (HP-2011).
https://www.amazon.com/dp/B00353M2P...olid=3MYY1OQK1UL4M&psc=0&ref_=lv_ov_lig_dp_it
Also have used these (M1-212A):
https://www.amazon.com/dp/B004A6LUN...olid=3MYY1OQK1UL4M&psc=0&ref_=lv_ov_lig_dp_it
The Mobil is on the truck now and I think the oil pressure is a hair lower when compared to the other. Someone else posted about such too. Switching back to the K&N next time to compare.
Changed the oil and filter recently, back to the K&N from the M1 filter. While not measured, the oil pressure needle is definitely a little higher now.
BG1988
There are many good oil filter brands, but I prefer the Fram XG series for my vehicles. The Fram XG10060 should fit your Tahoe? at a WalMart near you?
http://www.fram.com/parts-search/XG10060/
fram is garbage I tried one :(
i had to change the filter and oil shortly after since it stopped filtering after only 1700 miles and have to spend another 50$ when i was able to get 1/2 year out of other much better filters(3500 miles)
PG01
Up here to the right
Ive never, not once, ever......in 30 years of oil changes ever had a problem with fram filters....not sure what everyone’s problem is with them but i have a 2008 accord dd with 350k still running a Fram oil filter, 10-12k ocis with mobil 1 and never a problem with the filter.
BG1988
I need a filter that last as long as possable
since my Tahoe has zero sludge in it.. why would I take a chance with a cheap paper filter I don't think the fram filter would survive 70-75PSI anyways.. that is what it's topping out at cold start up
on the cheapest fram filters they use cardboard end caps ....
CARDBOARD end caps
PG01
CARDBOARD end caps
Well, tbh..... never said i used them on my tahoe.....:shrug:
But, if they last in my dd’s for 10-12 even 15k oci’s, without incident, ever, i personally wouldn’t hesitate to use them on my trucks. But, to each their own.
scottd
