Audio, side view cameras, 2nd Battery, Big 3
Meccanoble
Georgia
This is awesome. I definitely learned a lot. Appreciate you posting this stuff! Just to confirm, the power inverter is for something else or do you need it just to power the cameras?
Chrismnj
Chrismnj
NJ
All cameras are 12v so they run off of the battery, inverter is pretty much for any 110v accessory
Chrismnj
Chrismnj
NJ
Ok, here it goes 2ND part. INVERTER INSTALLATION.
1.external switch install for inverter.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
I wonder why GM didn't put a 110V outlet in the rear on these like they did with the minivans. Same with a hose and pressure gauge off the compressor to fill the tires, bicycle tires, balls, etc. That being said, the Hybird portable air compressor we keep in the truck does have the adapters for filling footballs and pool toys and such.
PG01
Up here to the right
New models have the outlet now, but in back of center console...
Chrismnj
Chrismnj
NJ
with this said, it would be nice, but for my needs I rather do my own, I know I can run a full size fridge on my set up, if you know what I mean :)
Chrismnj
Chrismnj
NJ
What is the sine wave do/doesn't do? I've been wanting a power inverter for my work van.
Modified its cheaper than pure sine, pure sine is same power as you have home, so some home appliances might not run on modified, there is much more to it, but I am not the ideal person to explain lol
Shunto
Long I$land NY
2000 watts continuous power, 4000 watts peak power, Modified Sine Wave.
I had an Inverter installed in my work truck at a 2 way shop. They used a relay for the power line. i think this way the box wont come on w/o the Ignition... I wanted to see the way they did it but the wires are pretty well hidden. Was the relay hard to wire in?
Chrismnj
Chrismnj
NJ
I have connected to existing switch in the unit.
Chrismnj
Chrismnj
NJ
all wires are through the box
ground wire for inverter
switch connection
Are you serious about that ground? I feel like I must've misunderstood something because you seem to know your stuff electrically everywhere else, including doing the multiple batteries, Big 3 upgrade, etc. But that ground for the inverter...
Chrismnj
Chrismnj
NJ
for some reason inverters on board remote switch doesn't work without external ground just the way manufacture wired in, and I am doing 3 way switch on that, on the other hand more ground points win win
going under the truck with wires.
I thought you were grounding the inverter on the battery lug with that tiny wire instead of the 0 gauge.
Looking back at your other pic, I see that there's a small ground lug and that's what you attached it to. The pic in post #61 looks like you grounded it on that main lug. It's just the angle of the pic. Carry on!
Chrismnj
Chrismnj
NJ
look from under, I did put automotive silicone around
No faith, LOL
Candielaine
