Ilikemtb999
Denver
Guy I found on EBay out of Texas will ship me four 7/16-14 x 3 1/2" L9 bolts and 8 washers for $11 shipped. He is looking to see if he has L9 lock nuts to go with them.
I wonder why nobody ever made an offset T bar for the strut. I bet you could have a 1/2” offset one and then could have it on top of the strut yet lower it 1” (since it’s 2:1). Hmmmm I do have some machinist hookups.
Ilikemtb999
Denver
Funny, I just quoted that same article on another forum a little while ago! Big fan here of the Crane Cam Trio and especially like the first, the smallest cam, for mine someday.
I just got my TSP vvt stage 2 cam in the mail yesterday. Just need to find the time to install it now.
Ingeniously simple idea. I think a forged offset T-bar would be great. The trick wold be getting it into the shock eye. A two-piece bushing would work, but how long would a two-piece bushing last? Or maybe a two-piece T-bar, like male and female halves? Press fit to eliminate wallowing?
Ilikemtb999
Denver
I have qa1 coilovers on my Buick and it uses a multi piece bushing with clips to hold everything together. Seems pretty solid. Their T bars aren’t offset though. I need to get my hands on a stock T bar
Blue Rock
Tallahassee, FL
Replaced my driver's side motor mount today (no more take off clunk). FYI for those replacing this themselves, it's not too bad of a job. My truck is a 2007 Chevy Tahoe 5.3. Thanks to this forum I used the Hummer H3 passenger side mount which is the same as the Police PPV mount GM Part number 25847739. I got it on Amazon for $85. This was the second time I replaced my mount since owning the truck, so opted for the more heavy duty this time around. I was able to access the bolts on the block much easier from underneath the truck than trying to fight them from up top.
kbuskill
NE. FL.
Or you could buy lower control arms that are drop arms.
I doubt very seriously that there would be enough room for the off set T-bar between the strut and the arm.
Here...
Unless it was a lot more shallow.
I felt the same way at first about bolting these up like this BUT a couple things sway my decision.
1st off... Rough Country is a pretty big company with a well known name and a lot on the line to loose if something should fail. I am certain they did their homework on the shear strength of the bolts in this configuration before allowing them to go to market. My guess is grade 8 was probably sufficient and they said "let's include L9 hardware just as a CYA". I am certain they don't want to be liable for any injuries... or worse.
2nd... @07Burb has been running his like this for a while (20k+ miles) with no ill effects and, I'm not knocking him or his truck, I don't even think that the shop that installed his this way even used the "grade 9" bolts. From the pic I saw it appears that they may have just reused the factory bolts. I base this off of the fact that all of the L9 hardware I have seen has that gold (yellow zinc) color to it and his don't appear to be that way. Although I may be mistaken.
I just don't see it being a problem for normal everyday driving.
Now if you were jumping ramps with your truck I could see the potential for failure but even then I would just about bet on breaking ball joints before breaking two 180,000 psi minimum tensile strength rated bolts.
I believe I will order 3.5" bolts because the factory bolts are 3" long and I would like a little extra length so that I can install a second nut to act as a lock nut on top of my actual lock nut on top of the blue lock tite I intend to use... definitely don't want them backing out.
The guy that mentioned the castle nut and cotter pin has a good idea but I don't know about drilling an L9 bolt... that may prove to be a chore plus it might possibly weaken it some how.
I think the lock tite + lock nut + secondary nut will be just fine.
Brian12019
