New to Me - 2016 Yukon Xl Denali
G00se
Newport Beach
I recently bought this 2016 Yukon XL Denali 4wd used with 60,000 miles (clean carfax, regular oil changes, local 1-owner, very clean) from a local dealer who got it in on a trade for a 2019 Navigator. I was happy with it until I started to notice two issues 1) Chevy shake (like driving over rumble strips) at varying speeds from 35 - 55 mph. I think this is it PIP5337E. 2) Very stiff suspension (rides like my 96 F 250 did). For a truck that stickered at $75k new, this is pretty frustrating.
Here's the steps I've compiled to fix the Chevy Shake. What have I missed or is anything out of order? Am I looking at big dollar signs here?
  1. Check tires, road force balance (tires are brand new)
  2. See if local GMC dealer can install software upgrade
  3. Flush the transmission, lines, cooler, replace filter
  4. Check drive shaft
  5. Check the torque converter
  6. Check front and rear ring and pinion gears
  7. Check tie rod ends (not just the boots, but where they are tightened against the knuckle and the inner rod)
Stiff suspension:
  1. Check Shock dampers
  2. Check MRC system
I've got the Black Bear Autocal, but I want to fix these issues first. Then I look forward to seeing how it feels in the snow and pulling the boat.
Pic attached of it sitting at the dealer before I bought it.
MichaelSE
2010 2500
Tucson
Sucks that you're having those issues. The stiff ride may be due to it having 22s, and also just due to it being a heavy BOF vehicle. I used to have a NNBS 1500, and even on 18s, it rode rough - rougher than most half ton crew cab pickups I have ridden in. I attributed it to the slightly shorter wheelbase and higher weight of the SUV platform. I As for the shake, your list is good, but also take a look at the tie rod ends - not just the boots, but where they are tightened against the knuckle and the inner rod. I have actually seen a case where the nut holding the tie rod end to the knuckle somehow loosened a bit, allowing the stud to move within the knuckle a few mm. It was not loose enough to be noticeable when I just looked at it, but jiggling the end a little bit it was clear there was play.
G00se
G00se
Newport Beach
The dealer I bought it from is going to do a free diagnostic. The local GMC dealer service manager said he had two trucks in the past week with the vibrating issue that was fixed by replacing the torque converter, $1500-$1800, and took a little while to get all the parts in.
Jorge1313
First thing is first you bought your self a beautiful SUV. It look gorgous I’m a sucker for white and black .You gonna have issue with it but minor stuff the hard ride is the 22 wheel. They make you ride worst than ford 250. It bright side it weights down the vehicle to give it better handling so you don’t flip plus their heavy too more stable at higher speed. Second you won’t have any problem feeling your towing with the 6.2 engine . The engine said by a gm mechanic is great on towing. Just drive it on a trip to get the better feeling of it and bond to it. Sound weird I know but when I first got mine after a while a noticed few small issues I began to get upset at minor stuff. But a moderator here in the forum and others too told me take a trip with it . I did and we bonded felt how useful it was and comfortable 6 hours driving and full t adult and how safe it felt . All the small glitches I found just grew with me . There not a perfect SUV but they make up for it in the look and comfort. Enjoy ok
G00se
G00se
Newport Beach
Hey another SoCal member! Awesome! Welcome! Nice looking truck! Hopefully you get some resolution on the issues soon!
How does yours handle the snow?
Thanks, took awhile to find Summit White and Black with all the options I wanted.
adventurenali92
Big Bear Lake, ca
Well I have a 2006 with AWD. Mines not a new model like yours with 4WD. Haha. With that being said, my truck handles in the snow fantastic! It’s pretty much a tank! I’ve had it three winters, the second of which we had quite a bit of snow. And I haven’t met a situation in snow yet that has gotten my Denali stuck. It’s very capable in the snow!
adventurenali92
Big Bear Lake, ca
Are current gen Denalis offered with 4WD? I thought all Denalis were either AWD or RWD.
The 2002-2006 generation Denali was only offered in AWD. The 2007-2014 Denali package was offered in RWD and AWD versions. The current 2015 and up models have a selectable transfer case with 2WD, auto4, 4HI, and 4LO. That was a new option for the current generation when it was introduced.
G00se
G00se
Newport Beach
My local dealer diagnosed the “shudder” / rumble strips feeling as the torque converter — they’re replacing it now under powertrain warranty and hope to have it back to me tomorrow. They said it also needs a software upgrade as part of the fix which is only covered under the bumper to bumper warranty and costs ~$450. The dealer I bought the truck from agreed to split the cost with me.
After this, diagnosing the super stiff suspension is next. Probably an alignment as well as I’ve noticed the driver side tire is starting to round on the outside edge.
bamachem
My dealers started with a trans flush and software update @ 57k miles, free of charge. Fixed my shudder issue.
Tahoe14
Central Fl
Software upgrade is $450, Wow!!!! is that ever expensive. I think I would call GM customer service and see if they will help you with that expense even with the Dealer splitting the cost. I don't think they should be charging you anything.
fiatdale
Houstons Best
Houston
Not to play devils advocate, disclaimer: I work in a gm body shop, not service dept, but if you buy something out of warranty, expect up front that you’ll need to pay out of pocket for things like software updates, and not get them for free. If they do it for free, great, but it’s still the service techs time to do it.
Tahoe14
Central Fl
There are two other owners on another thread in this forum that report that their Dealer took care of the same repair at no charge and I believe both were out of their 3yr/36,000 warranty and was handled under the power train warranty. makes no sense and no consistence.
G00se
G00se
Newport Beach
Update: I waited for 1.5 weeks for the dealer to get the parts that were on back-order to replace the Torque Converter. Dealer was also out of loaners cars. Dealer finally called saying the parts are in and they have a loaner for me (GMC Canyon...brutal), but they said GM Corporate just relayed there's a change in process (effective October 4th apparently). Dealers have been told to to do the software upgrade and transmission fluid flush first, then if the problem still exists after ~200 miles of driving, replace the TC. I wouldn't have to pay for the software upgrade as the Dealer previously said so I agreed. I'm about 50 miles in and so far and have not felt the vibration at all. I still have the occasional long/delayed shift between 1-2.
Plan to do the bolt mod this weekend and BB autocal data log. Hope that helps. Will continue to update.
dizhai
