1BADI5
DMV
Well I bench bled and installed a 02 Silverado Master Cylinder today.........easy breezy!
But all that starts easy never ends/finishes easy right.
Well I got my Motive pressure bleeder set up and ready to go. The first bleeder (right rear) cracked open, but no fluid was coming out. Ok, move onto the left rear.....the bleeder breaks of F' ME sideways. Well lets see what happens up on right front caliper; I prepped it with a spray of Kroil and some heat......that MF'er broke off too!
So in order to flush the DOT3 which looks as old as the truck, I will end up replacing both rear wheel cylinders and both calipers. F' it, it will all be done and new.
Shadowz Edge
I pulled my TB to clean it up as well as the IAC area of the TB along with the MAF and replaced the TB gasket as well ... Out for a test drive as we speak.
So far idle has improved by 100 RPM at both parked and in drive and is a little snappier. And no I did not do the TB plate mod nor the air box expansion delete.
TARDIS
Jersey Shore
LED Headlight Conversion.
LOW Beam
5421F9A6-1E68-49D1-9953-4C783E7AAE15.jpeg B417FF93-C4A6-48EC-8D8B-5A712B8D73A5.jpeg A0C97D75-AEE9-4CE9-B694-5C186A1FAAD6.jpeg 18C05DB9-ED2E-47EC-8A83-4078AF11F834.jpeg
fastpat
Upcountry South Carolina
That's bad about the wringing off the bleeder screws. Still, wheel brake cylinders are cheap, and the calipers can either be taken off and have a removal tool used, or a rebuilt caliper used. They're just over $100.00 per pair.
Shadowz Edge
Went to the Tahoe this morning only to find my battery died due to me leaving the lights on yesterday (buzzer was removed - whoops).
So I'm planning on heading to the salvage yard to see if I can locate a drivers side battery tray and give her an upgrade ;)
Shadowz Edge
Nice, those lights on reels are sweet.
Thanks! I'm hoping to see if I can put 1 in my Tahoe and actually have it work. And 1 of the battery trays I'm going to install in the Tahoe for a dual battery setup. ;)
Will def work. I have one also. I need to put it in my 03. Gotta put an led in there. It'll reach all the way to your rear bumper.
NjA4207
