Lowering 4wd?
Gmoney15
Hey all. I’ve had tons of lowered silverados and I’m looking at buying an 07 Tahoe to lower like 2/4. I cam across a great deal on one but it’s a 4wd. I know you can lower it but are there any pros or cons to doing so? Or can I remove the driveshaft and axles since I probably not use it very much? Is the mpg or tire wear worse with 4wd? Thanks in advance
With only a 2" drop, you can keep it 4WD. I recommend spindles for this. MPG is rated (I think) something negligible like 1 MPG less than 2WD. Tire wear should be the same as a 2WD since the suspension is essentially the same.
Jibee
Mine is AWD and lowered 4/6 with no issues at all. Aligned properly and drives great with no vibrations at all.
Graystone_OG
NYC
Not sure the about the rear end set up on these. I lowered my 09 Sierra 4wd. It was 6/8. Still had the axles in and worked too
Sent from my SM-G928V using Tapatalk
nice. Is your truck lowered on arms and spindles?
dszx13
Springs, struts, and spindles. My current truck will be lowered with 6" arms. The ride quality wasn't that great. Hoping this route will be better
Graystone_OG
NYC
Oh ok thanks. Yeah the spring and strut combo probably made it too stiff.
G
Gmoney15
This makes me feel better for sure. Going Saturday to pick one up and lowering it next day!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i have the complete kit with rear endlinks/bumpstops and shocks all around 850 shipped. Also 150 mail in rebate after.
email me [email protected] if interested
BWASTEEZE
