Lowering 4wd?
Gmoney15
Hey all. I’ve had tons of lowered silverados and I’m looking at buying an 07 Tahoe to lower like 2/4. I cam across a great deal on one but it’s a 4wd. I know you can lower it but are there any pros or cons to doing so? Or can I remove the driveshaft and axles since I probably not use it very much? Is the mpg or tire wear worse with 4wd? Thanks in advance
Def don't remove the axles.
With only a 2" drop, you can keep it 4WD. I recommend spindles for this. MPG is rated (I think) something negligible like 1 MPG less than 2WD. Tire wear should be the same as a 2WD since the suspension is essentially the same.
Jibee
Mine is AWD and lowered 4/6 with no issues at all. Aligned properly and drives great with no vibrations at all.
Graystone_OG
NYC
Not sure the about the rear end set up on these. I lowered my 09 Sierra 4wd. It was 6/8. Still had the axles in and worked too
Sent from my SM-G928V using Tapatalk
nice. Is your truck lowered on arms and spindles?
dszx13
Springs, struts, and spindles. My current truck will be lowered with 6" arms. The ride quality wasn't that great. Hoping this route will be better
Graystone_OG
NYC
Oh ok thanks. Yeah the spring and strut combo probably made it too stiff.
G
Gmoney15
This makes me feel better for sure. Going Saturday to pick one up and lowering it next day!
NORCAL SS
SUV SUSPENSION GURU
i have the complete kit with rear endlinks/bumpstops and shocks all around 850 shipped. Also 150 mail in rebate after.
email me [email protected] if interested
juan84
Mounds view MN
U should be fine I'm at 2/3 on my 14 xl denali awd rides just as stock did.. kit came with the shorter links for the factory air shocks out back I got my kit from Tony first pic with factory 20 the rest with oem 22
Sent from my SM-G920T using Tapatalk
NORCAL SS
SUV SUSPENSION GURU
Guys ive been swamped.... feel free to text me if you have any questions
VDV18
That white Denali looks great, but seems lowered more than 3" in the rear....doesn't it?
juan84
Mounds view MN
Could be the extra weight of the xl I put the springs plus the spacer that comes in the kit which makes it 3 inches
Drewphil
