Ordered a Pioneer DEH-S6000BS today. Should be here soon. Not gonna worry about much more of the sound system aspect for a while but this will at least be a good basis for when I start down that road at some point.
My99Yukon
Finally got around to:
A.) swapping the 3.42 to 4.10 diff regear.
B.) Also, tore into the transfer case that was plaguing me for the last several months.
i found out that the old shop had installed some parts bass-ackwards which caused some parts to overheat, melt and fuse. No wonder the 4lo wouldnt engage. So with that, the only other item on my checklist is the MPFI which I hope to tear into this week before my next trip.
Got the wiring harness wrapped up for the stereo in the 99
99YukonSLT
Ohio
Recap over the last few weeks -
Flowtech Ceramic coated headers - done
EGR Delete - done
Replace all bump stops - done (minus one that was bad out of the box)
GM 05+ Electric fan install - done
Still need to get my LF axle seal & front diff fluid changed at some point.
Just about ready to get the new flooring laid. Sound deadener installed
ObsUkon
Yakima
Picked this up as a "mechanic special" ($500 140k miles) on CL, swapped out the fuel pump and replaced leaking intake manifold gaskets and related gaskets as well as water pump. Gave it an oil change, coolant flush, front and rear diff service, replaced front brakes (metal to metal), replaced inner and outer tie rods, gave it an allingment and balanced wheels. Will finish up the "Tune up" sometime this week. Runs like a champ as is. Had the front windows tinted to match the rest and installed my spare sound system. Ordered a set of Aftermarket headlights last night, led interior lights also on their way. Full detail coming up as soon as the guys at work can squeeze it in.
DallasTahoe
Had to use Project White Girl to tow my sons car into our 30 degree rear driveway since he totaled it yesterday...
fastpat
Upcountry South Carolina
Exactly what had they installed incorrectly? This info would be valuable as a check for inspecting the work of other shops.
JohhnyTsunamii
Added a bottle of Amsoil Slip Lock to my G80 diff. Stuff worked amazing. No more chattering. Replaced broken hood release lever with a freebie from the junkyard. Replaced purge valve with junkyard freebie. Replaced two broken wheel studs (grabbed six like new junkyard freebies!). Grabbed an oem sub-box and rear kick panel from a 2001 yukon thinking it would fit but not even close, they are going back to junkyard tomorrow. Removed annoying DRL light dash light (DRL disable mod done last year), put LEDs in my climate control (need to swap polarity on a couple of them tomorrow). All in all a good day.
qukon 95
Well replaced ac compressor,new hi/low line BUT I had to cut the drier off ,the theads was rusted together I cut little of the evaporator line that the o-ring sits on DamDam so I need to pull the dash to replace it. Now the small line to condenser won't loosen to replace orfice tub the line is twisting so I will get a new line. AND that PB blaster is awsome
View attachment 200433 View attachment 200434 View attachment 200435 View attachment 200437 View attachment 200438
Not bad for $500. Gotta sew that seat up tho.
Got a pic of that sub box? Where are you located?
JohhnyTsunamii
looks like this one off ebay. I paid $15 for it at the junkyard. Just ordered a cheap 8 inch sub off amazon and was planning on throwing it in my little crx daily. If you want one let me know, Im in minnesota and our junkyards are literally full of tahoes yukons and burbs.
I've been wanting one for awhule, but I'm sure shipping would probably be crazy. I'm in Nj. I have an 03. Is it heavy?
dkknaebel
Keeping LKQ in business
St. Petersburg, FL
This weekend was the best weekend ever for Ol' Black Betty. Finally, finally, finally got my transmission leak sorted and stopped. Washed and cleaned her up, took her to the beach and all around town. She is finally a true daily instead of just 6 miles back and forth to work. Replaced the ignition switch which cured a lot of weird little issues I was having. Of course when we pulled the old one out, it had come from the u-pull-it. So much better!
ObsUkon
Yakima
Removed all door moldings and picked up some new wheels and added some black housing headlights....
wwiizz
