6.0 swap
OhioHoe
Southern Ohio
@Tonyrodz If you don't mind me asking, approximately how much of that $7700 was due to labor costs? Just curious because I have access to a facility and friends that would allow me to do most of if not all of the labor involved in the swap, other than the tune.
Maximus1
I could be wrong but I believe that the 4L80E is actually a 4L60E with upgraded tougher internal parts.
boomboom baker
boomboom baker
Tennessee
Ok my Tahoe is a 2001 what year 6.0 should I get can I get it from a Yukon because I found one with 100000 miles on it doesn't matter because we're going to rebuild it anyway its a 2003 out of a Yukon can I use it also seen a totaled out Chevy ss truck I heard they had the 6.0 and they were bad ass but not a fan of aluminum block did they make iron block ss if so what years cause I saw 5 at two different junk yards today totaled out I think one was a clone
HiHoeSilver
Away!
Chicago
Nope. The HD 4L60E is the 4L65E. The 4l80e has different ratios, not to mention different bell housing dimensions, etc.
'03 would work. You'll probably have to swap on your current throttle body because '03 switched to DBW. But the DBW TB on those earlier motors were still the same 3-bolt pattern as the older DBC TBs. My thoughts on getting a 6.0 (LQ9, which is iron block) from a Silverado SS is that the chances are that it was beat on because it was an SS. When I was shopping around for an LQ9, I wanted one from an Escalade because it's the same motor, but chances are slim that it was beat on. If you're gonna rebuild it, then it doesn't matter it's history (other than mechanical wear/damage). Also, if you're gonna rebuild one, why not get an LQ4? It's more common and therefore cheaper and may be cheap enough that you can invest in some go-fast goodies (flat-top pistons- maybe forged?, cam, head work, headers, etc.). The LQ9 has a few upgrades over the LQ4 besides just the higher compression from the flat-top pistons. But, again, this may not matter depending on how in-depth you're gonna rebuild it/build it up.
Man! What yards are around you??
bottomline2000
Dallas, TX
4l80 is closer related to a th400 with OD. Think RV transmission. A STOCK 4L80 with shift kit beats a fully built 4l60. I got my 6.0 from an 02 2500 suburban that had a 4l80. If the motor came with a 4l80 u will need to use the 4l60 flex plate since the 80 plate is flat with a spacer and has a 6 bolt converter pattern..
I hated myself for not going 4l80 when I blew my transmission the first time. Given a 2nd chance I'm going 4l80 and not looking back. 6.0 torque is so much stronger and being modded makes them feel like it wants to rip the guts out a 4l60.
Our06hoe
Did the 00-06 years have a 6.2l? Would it be worth the headache to do that swap or just stock with the 6.0 swap?
bottomline2000
Dallas, TX
No, 6.2 started in like 2009 or 10. It would be a lot cheaper to do a 6.0. I'm sure my cammed 6.0 would give a 6.2 a nice run for the money at half the cost plus you would have compatibility issues due to the 58x reluctor wheels on the crank..gonna cost ya to swap a 6.2 into a nbs.
What year did the 8 liter start?
Maximus1
Interesting, I know a guy who owns a transmission shop who can build a 4L60E that can handle up 900 to 1,000 horsepower installed for $2k and setup as a daily driver. If built with similar upgrades I wonder what a 4L80e could handle. I'm expecting that the parts might cost more but not too much more and the labor would be the same cost. I wonder if the 4L80E would be a plug and play on my 2004 2wd that originally came with the 4L60E? Are the lengths the same and would the computer accept it? Plus if the wiring and electrical plugins be the same. Not that I would ever plan on having a 1,000 hp as a daily driver but since I'm already planning on having 4L60E built to handle 600hp
Maximus1
Agreed, I beat a 6.2L with my 5.3L (that has been let's just say mildly upgraded) by about 9 car lengths. And I haven't spent near what the same upgrades would cost on a 6.2L
Maximus1
Would it be relatively easy to do a swap to a 4L80E? Are the lengths and plugs the same. I already have 3.90 gears so I'm not too concerned with the ratios.
bottomline2000
Dallas, TX
Transgo says a 4l80 would be good at that power level with just their shift kit lol. Hard to imagine a $2k 4l60 handling that kind of power. 4l80 are beast transmissions. The transplant can be done..4l80 is a little longer..you need an adapter harness or repin your factory harness and add a 2nd speed sensor to the front..modify your crossmember or buy a custom one to move the transfer mount back some. Custom converter to fit 4l60 plate or change to a factory 4l80 plate and spacer and a tune to control the transmission ..yeah..I'm working on making this happen..
