07+ Brake upgrade on a 00-06 NBS, is it worth it?
ATIII
Brighton, CO (Denver)
Which rotors and calipers did you go with?
NAPA Eclipse:
SE5469A (right)
SE5470A (left)
The calipers were in NAPA Boxes, but were reman GM stamped calipers.
Rotors:
Power Stop - AR8654XPR
SS Lines:
Centric or Stop Tech - 950.66001
Sent from the *******, mid-push.
CdnDenali
Just confirming this upgrade is for my application?? For 2001 Yukon Denali XL (front brake set-up) and parts would be from 2007+ Tahoe (calipers with mounting braket and hardware with 13" rotors)?
TheAutumnWind
That is correct.
TheAutumnWind
I would get high quality Dot 4... Get synthetic Dot 4 that has the highest boiling point... Price is not too relevant. I would not cheap out on brakes. :D
meh DOT4 has a higher boiling point sure, but it also absorbs water more quickly. I am running dot3 synthetic. Not gonna get it anywhere near the boiling point on that in this truck... we're not doing hot laps on daytona here.
Correct!
Blue 04 Z71
Reading PA
Did this swap on my truck. Best thing I've done for stopping. I used the ac delco slotted rotors and power stop ceramic pads in the front. Ordered everything for a 2005 with rear drum brakes. That gives you the 13" rotor and get the calipers for the same truck. The rear I have Silverado SS dual piston calipers and ac delco slotted rotors with OEM ceramic pads. Best it's ever stopped.
TheAutumnWind
Huh, this whole time I had no idea that the SS had dual piston rears. Looks like according to Rockauto they are just front calipers in the rear!
FitsRear Left; Silverado 1500 HD; with Phenolic Piston Caliper
OrFront Right; Silverado 1500 Base Model; Rear Disc brakes; with Phenolic Piston Caliper; with Brake Code JC4; GM Brake Codes are on the "Service Parts Identification" sticker.
OrFront Right; Silverado 1500 Base Model; Rear Disc brakes; with Phenolic Piston Caliper; with Brake Code JH1
OrFront Right; Silverado 1500 Base Model; Rear Disc brakes; with Phenolic Piston Caliper; with Brake Code JH2; GM Brake Codes are on the "Service Parts Identification" sticker. (Only 6 Remaining)
ATIII
So does this mean there is a way to upgrade the rear calipers?
Blue 04 Z71
Reading PA
They aren't front calipers. When I buy pads I buy them for a 2003 suburban. They are just the SUV dual piston rear calipers
MadDogDelpho
Texcellent
Seriously considering this upgrade after my little accident the other day. Anyone know the best place to get all the parts together? IMG_1329.JPG
TheAutumnWind
odd listings for rockauto then.
Can you show specifically what rotors and calipers you purchased?
jarydM
Lost in the Woods
Tennessee
Seriously considering this upgrade after my little accident the other day. Anyone know the best place to get all the parts together?View attachment 78552
My goal is to pick up some Calipers from a junkyard for the front rotors, and just refurbish them myself, and paint them. Them get some of the 13in powerstop rotors for the nnbs trucks, and some SS lines. Not in a hurry on this though, gonna start browsing the junkyards now that the weather is good enough.
MadDogDelpho
Texcellent
I figured a junkyard would be the best bet. Or people parting out their trucks on craigslist. Are the NNBS pickup front brakes the same as on the SUVs?
The NBS rears are actually better than the NNBS rears. They're dual piston 13". NBS had 12" fronts and 13" rears dual piston. For the NNBS they switched and went with 13" fronts and 12" rears dual piston. So if you switch to the NNBS fronts on your NBS you now have better brakes than the NNBS, 13" front and rear dual piston.
Blue 04 Z71
Reading PA
You must run 17" or larger wheels for these front calipers. My 16" steel spare does not fit anymore. Just a FYI
Power stop s4918 calipers for the front
Ac delco 18A1705SD or raybestos 580279per for the 13" front rotors.
Pads for the front I got the power stop z361092
Rear I have OEM ceramic pads on
The raybestos
580165per
Hope this helps
Durobans
