what should i change? steering/suspension wise?
riviera rider
putting some 28" rims on the tahoe and dont want any problems with wear on the tires (they cost 1200$ each) im thinking all balljoints and tie rods anything else i should swap out? ive got 157k on the truck and would like it to be done right
thanks guys!
AtomicHoe094
Atomichoe094
cleveland, OH
all that ***** going to wear out faster then normal anyways.. just let it be, and when something breaks then replace it.. IMO
haks310
Got LEDs?
SoCal
LMAO
How bout your breaks? That's a lot off wheel to stop and the rotors are going to look tiny.
bai78
Surviving
Dallas, TX
Extreme big brake/slotted rotor upgrade along with stainless steel lines. You may want to consider a hydroboost conversion.
blackcoffee
O.G. Black.
x2 on brakes, SS brake lines the shocks, pitman and idler arms, sway bars. Its definetly time to swap out. When I first bought my truck it has 20" wheels and let me tell you I hated it! I can't imagine 28" wheels on these things... In my opinion it would ride like shit and it's just throwin money into something that really doesn't look good with 28" wheels so save some of that cash for awhile cause you must have quite a bit I assume and buy a slightly used mint 2008 Tahoe flashy as shit, I just don't even get why too? To get women?! I've got 16" wheels and girls like to ride in my truck. Maybe you should reconsider ha. No offense ofcoarse...
bowtiefreak
No Quarter
Near Philly
Brakes, and big brakes at that. Not just a disk and pad upgrade. I have no idea how much a 28" rim weighs but that is going to be a lot of rolling mass. Can you say brake fade?
riviera rider
riviera rider
lol i got the rims already i traded my 96 monte and some cash for the rims, i do custom paint work as my profession so i decked out the monte for pretty cheap and got a steal on this trade, the truck is barely going to be driven im just pretty much just putting the rims on painting the truck and gonna sell it probaly this summer after a few car shows. i tend to go through cars quick, i think i had around 5 this summer alone. so i just want to change shit that may be needed not to **** up anything while i am driving it.
planning on doing a drilled/slotted rotors with some high performance pads, all tierods/ball joints and idler and pitman arms
shocks have been replaced and maybe ill look into the sway bars also
thanks guys i appreciate it!!! heres a pic of the rims! (its just sitting next to the truck not installed yet)
haks310
Got LEDs?
SoCal
LoL ******* look like they are installed already. They look good, a bit too big for my taste though.
You might as well do stainless steel brake lines if you are doing the rotors/pads.
riviera rider
riviera rider
what exactly do i have to swap for the stainless steel lines? the whole entire brake line system throughout?
riviera rider
riviera rider
oh ok, ill make sure to do that then, where do i get the peice for that??
haks310
Got LEDs?
SoCal
You can pick them up at Kragen, just ask to see their Russell catalog and have them order it.
Or you can get them from SummitRacing and order a Baer big brake kit while you are it also.
Brandon X
Michigan
Holy shit lol. I'd love to have some 26's or 28's but il never be able to afford them. Looks good though, even though id personally put on a 3" body lift.
Like everyone said, tie rods, idler & pitman, sway bars, ss brake lines, and of course GOOD pads. Then you should be golden.
NORCAL SS
SUV SUSPENSION GURU
invest in brakes. I did 28s on a 3 inch lifted tahoe and man it didnt stop worth shit.
riviera rider
riviera rider
i was actually contemplating the 3" body lift and seeing if it would make me clear everything with my front turning radius, (using adapters so the rims poke and hit the bumper and fender as of right now when i test fitted one)
only thing is i need to put all the rims on and see if i can fit the truck in the garage with the 3" lift i think its going to be close
whats a good brand or place to get a 3" body lift kit? and is it installable by me or one of my bodymen at work you think or should i have someone do it for me?
---------- Post added at 02:18 AM ---------- Previous post was at 02:11 AM ----------
found this one and it says it comes with the front bumper brackets now wouldnt i need some for the rear bumper also to be lined up???
http://www.suspensionconnection.com/cgi-bin/suscon/123.html
AdrienR
