At this rate, this vehicle has no chance.my thoughts exactly, who does that? unless you know the plugs are fresh and 1 happened to crop up with a problem.
Yeh I kinda thought you should just replace all them at once though they may be fresh my dad has had the vehicle for a lil.my thoughts exactly, who does that? unless you know the plugs are fresh and 1 happened to crop up with a problem.
It’s not a riding mower.. it needs 8 plugs! WTH??!Yeh I kinda thought you should just replace all them at once though they may be fresh my dad has had the vehicle for a lil.
Then, as the owner, you get to tell the tech what you want done and he/she can say, yes or no, and then you decide if you have them work on it at all.Yeh I kinda thought you should just replace all them at once though they may be fresh my dad has had the vehicle for a lil.
Pretty much. Sometimes it will catch on first crank and sputter and then run. Second crank always cranks right up.Hail Mary, but does it act like this? (Vid taken about 20 minutes after getting home - still warm):
Is it still on the factory camshaft position sensor or an aftermarket replacement? Mine did like in the video, or as you said sometimes catch, sputter, then run with an aftermarket CMP sensor. Put an OEM one back in and not a problem since. I drug my feet on swapping, even did a fuel pump and pressure regulator despite knowing aftermarket sensors are garbage in these. At least I've got new parts on the fuel system now. LOL.Pretty much. Sometimes it will catch on first crank and sputter and then run. Second crank always cranks right up.
I’m pretty sure it’s the factory sensor but I’m not sure. I’m not the original owner. Seems like a pita to change too.Is it still on the factory camshaft position sensor or an aftermarket replacement? Mine did like in the video, or as you said sometimes catch, sputter, then run with an aftermarket CMP sensor. Put an OEM one back in and not a problem since. I drug my feet on swapping, even did a fuel pump and pressure regulator despite knowing aftermarket sensors are garbage in these. At least I've got new parts on the fuel system now. LOL.
Would yours smell like fuel when you tried cranking like in the video?Is it still on the factory camshaft position sensor or an aftermarket replacement? Mine did like in the video, or as you said sometimes catch, sputter, then run with an aftermarket CMP sensor. Put an OEM one back in and not a problem since. I drug my feet on swapping, even did a fuel pump and pressure regulator despite knowing aftermarket sensors are garbage in these. At least I've got new parts on the fuel system now. LOL.
Ok. Last question hopefully….I have a sensor on order.I never smelled for anything after a first crank failure. But mine runs pig rich (separate issue i'm looking into) so the garage smells heavily after starting in open loop.
No. That's the oddball, here.Ok. Last question hopefully….I have a sensor on order.
If you put the pedal down for “clear flood mode” would it crank right up?
