Warm Start Problems
j91z28d1
other thou I had was hold the peddle to the floor to clear flood before cranking.. then crank till you get good fuel pressure and then release the peddle
M
mcsc1
What about a snap-on scanner? That’s the only one I have access to.
Originally put in a Delphi pump and now the warrantied Delphi is a carquest. Fuel pressures are fine with key on engine off and also when running. After it bled down though to 16-18 psi and then turned key on it would only reach 24-26 psi after engine had been on and “primed”.
M
mcsc1
Yep that’s my dilemma. It acts like it’s flooded and it does lose pressure but everything I’ve done and looked at doesn’t show me where. I have a possible injector I want to warranty as all my plugs smelled like burnt fuel except one. That one smelled like raw gas.
j91z28d1
you could try unplugging that injector. it will fire on 7. but also even if one of the 7 is rich should still start. might not be the smoothest thing but I'd think it would fire. there's a guy here that disconnect 2 injectors and 2 rockers I think it was and driving on 6 cyl because of a afm fault.
M
mcsc1
I may try that to see if it’s my issue but definitely not driving on that.
ya that's a method to easily detect a misfire or other isssue's by pulling the coil harness off one by one until you no longer "hear' a difference
j91z28d1
definitely don't drive on it.. just crank and start.
since you have a scanner, if you can watch that and either cycle the key a few times or just clear flood till you have psi, and then let it crank. see what that does. I have a feeling your low pressure is throwing the whole crank routine off. I base that on nothing but a guess lol. they do sell check valves for fuel systems. normally only used for big aftermarket fuel systems using 2 or more pumps. but as far as I understand it, the pump should have a check valve in it.
the one that doesn't hold at work was from napa. we try to use oem these days.
if getting the pressure up first works, you might just have to go with a new oem from the dealer or gm parts direct. I don't trust Amazon and I kinda questioned some acdelco plug wires from Rock auto recently, they looked the same, but the oem I took off had a part number on the wire, these didn't. after getting burnt by Amazon acdelco parts twice now. I'm always worried if they are legit.
M
mcsc1
My pressure is great at cold start, running, etc. but it falls short only after it’s warm and bled down. I do agree though, it’s an issue I thought was solved by replacing the pump. Would anything else be keeping it from building pressure?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Thanks for all the suggestions. I too have thought control module but having it programmed to the vin doesn’t sound fun or cheap.
One spark plug smelled like raw fuel where the others all smelled like burnt fuel. So that could be my issue.
We’ve tried checking grounds in the engine bay and cleaned everything up a little. But nothing changed after doing that.
I had thought cam position sensor, but I hate just throwing parts. I’m unable to leave it for more than a day due to needing it for work.
I hate you are having this problem but you just said something funny to me. You just said, "I hate throwing parts", but you initial post lists a bunch of parts. Sometimes these rigs just drain the wallet.
M
mcsc1
Unplugged the injector I suspected of leaking and it starts much better. Runs like poop but it doesn’t crank for almost a full cycle like it does normally.
M
mcsc1
You’re telling me man! I thought I had the problem solved. Everything I’ve seen and videos similar to mind show the fuel pump or injectors. Replaced those and still have the issue.
M
mcsc1
Probably not this, but think about checking it to rule it out: read the alcohol content of the fuel. If you have a flex fuel engine and are not running E85, and the alcohol content reads more than 10%, reset it. That will also reset the LTFTs (which I see you've already done).
Found this on another thread. Anyone think this could be an issue I should check?
Your fuel trims would show a very rich condition on both banks and it would run like poo all the time, probably. But it's not a bad idea to look at what the scanner reports and reset the alcohol content, if not using more than E10 fuel.
j91z28d1
so you changed the injectors already? the only cheap way I can think of to check the injector is like said earlier, swap it another spot and see if that fuel smelling plug follows it.
do you have the old injectors around still? maybe could clean one and swap it in as a test? only thing I can think of to cause a injector to spray more than the ecm says to it a short to ground somewhere in a harness? I believe they are switched grounds and constant power?
M
mcsc1
It’s possible and I’m unsure how to go about finding the ground in the harness. But the injectors are warrantied, I can get another through that warranty.
Fuel trims might say something. You can use a noid light to see if the injectors are being pulsed. An injector balance test, using a bi-directional scanner, would show an injector that wasn't working properly (too much, too little fuel metered). Neither of those tests, however, would tell you if the ECM was pulsing them properly.
Timee
either maf or map pulls double duty, I think it's the maf, after 160k miles they are always suspect in my book, they can just go goofy after that
I have a 2009 Tahoe 5.3 2wd with 189,000 and I just brought it to my mechanic to change a spark plug and he only replaced one and said the others are fine but about 2 weeks later im getting a cyl 4 misfire but engine seems to run perfectly besides a little rough at idle. I dont have a spare maf sensor but if I unplug it and the engine light disappears does that mean its the sensor?
One spark plug, really! :banghead:
no telling without getting some readings on it with a scanner, when it is unplugged the vehicle runs in a default mode. I can say that after 160k the maf are known to/or can go goofy and can cause all kinds of problems. just throwing parts at it is a gamble, sometimes you win and sometimes you dont.
worleytrev93
