Uneven Tire Wear (Alignment Needed?)
M
MaizeNBlue98
I think you are over analyzing it, if the alignment technician finds anything out of spec they will tell you, for instance if they cannot get the alignment within spec there could be a worn tie rod, etc, plenty of reasons to be needing a alignment like pot holes, hitting a curb, minor accident, etc
Over analyze...LOL. I tend to do that. Appreciate the advice. Time for a alignment.
How is a 4-wheel alignment performed on a vehicle with no adjustment provisions to the rear axle?
Unless that's what they're calling a thrust angle alignment.
Jason in DLH
Cheeseburger and Fries
MN
Exactly right. I find it interesting that there’s no guarantee that both rear wheels are pointed straight ahead.
Now that I think of it there’s been times when I see a truck driving down the road and I swear it seems like it’s driving crooked. Must be because the thrust line is way off.
For anyone’s information to follow along...
91RS
GA
You need an alignment. The alignment sags after it leaves the factory and a proper alignment (meaning all things adjusted to center-of-spec even if "green") should be performed in the first few thousand miles and then it should be checked once a year or 12k miles after that. I'd bet you have something like -0.7 to -1.0 degrees of camber and the toe is out. Also, 12k miles is far too long on a rotation, it should be done every 5-6k miles tops. The Bridgestones are bad about wearing funny if you don't rotate enough or have a good alignment.
Sounds like the dealer wants to sell new tires. Go to a different shop and see. I’m no help on 4 wheel alignment. Sorry.
How do you figure? He said they recommended an alignment, not tires.
Those trucks that are "crabbing" down the road may have been heavily damaged before and the frame could be tweaked. I've seen it with cars, too.
sealandsky
Minneapolis, MN
I'd bet on a slight alignment issue that has manifested itself over the 25K miles on your rig. I just put on new tires at 19K miles and had the alignment checked - found right front was slightly out of toe spec.
@MaizeNBlue98, are you a rather big guy? Although it's usually with compact cars and trucks, I've seen where larger people cycle the suspension enough to make it ride too far out of spec, and mostly on the driver side. Having the vehicle aligned with them in the driver seat resolves this.
jacblev
