CTX-SLPR
See List, they're on there minus the oil pressure sensor. I've had the transmission harness out twice while chasing what I had hoped was just valve body issues, no heat gun needed then.A heat gun. Almost a necessity to unplug the harness from the transmission. It also helps to remove your intake, to tilt the back of the transmission down. Also to reach the upper bellhousing bolts. While you're in there you should consider a new oil pressure sending unit and intake manifold gasket
O2s are newOh yeah. Since the starters coming out, and if it looks really old.... It's a great time for a new AC Delco. Oil cooler line set. If you want to preserve your O2 sensors, I recommend taking them out before using any sort of impact on the exhaust. And well they're out.... It's a good excuse to splurge on a new set of O2 sensors, LOL
I have no oil cooler on the passenger model RWD spec. When the radiator needs changed I'll get the lines and add one but for now it's just a new gasket for the leaking block off plate.
