Tonyrodz's Tahoe Build Thread
Sam Harris
Texas
@Scottydoggs came by today to give me a hand with this beyotch. COOL ASS CAMARO--btw :D. Scott was able to scan my tune with his hp tuners. One of the O2 sensors looked a little "lazy" on the tune. I'd like to go with an AcDelco if the price is right. I googled but got a few different part numbers. Anyone know which would be a correct number? They are a little expensive, so I'd be willing to look at a Denso or NGK--possibly. Anyone have any suggestions? Something affordable. @Dantheman1540 @Rocket Man @915_Tahoe @Doubeleive ?
That’s awesome! Way to go @Scottydoggs!
I got this one--
What was the verdict on the tune?
Everything was pretty much ok, but bank 2 upstream O2 sensor was a little questionable. 1st it looked like it might've been bad, but when warmed up the numbers started moving, but very slowly, then while driving and when getting on it, the numbers were moving ok. So it was lazy. Better to just rule it out and to grab one.
So no smoking gun as to what your problem is?
Makes a guy wonder if a compression test would be good. Given what we know about the guy that pit it in. What if a pushrod is long or something causing a valve to hang open? IDK just thinking out loud.
He used the matching pushrods for the aftermarket cam. I hope internally it's ok.
Scottydoggs
NJ
that b2 o2 was like dead when cold, ltft were like a -4.5 on b1 and +14 on b2, voltage was very slow on b2 as well. but once driving the ltft started to match, then once back at idle the mismatched trims came back. voltage also picked up and about matched b1. seems like a the heater is dead and the sensor is lazy for sure. just not dead enough to set a code for it.
other then the o2 nothing jumped out at me as bad. no KR or any thing looked out of place. engine actual sounds pretty solid. we never got it to make that sound either.
we did try to read his pcm, but it timed out real fast, didnt want to push our luck and something go wrong, so i just quit. was not going to tell me to much really.
Thx Scott. Explained it way better then I ever could've.
So maybe there’s actually no real problem?
Scottydoggs
NJ
lets hope the o2 fixes up the fuel trims, and that should make the engine happier id think.
whats funny is his truck is way louder at idle then my SS is. his cam even sounds like its got more chop to it. mines rather mellow sounding but you can feel the engine doing a chop when you sit in the car. then once you get on it, im way louder lol
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Good man helping Tony and meeting up, good stuff.
curbud
