Throttle body cleaning
4WDTRK
sleeps in garage
Socal dreaming of Norcal
I've done quite a bit of searching and watched a few videos, but haven't seen too much info related to our specific engines. It's pretty straight forward stuff, but I'm wondering if anyone has any tips? Should I remove the throttle body or is cleaning still attached ok? What about the IAC? Thanks!
08HoeCD
I thought that SeaFoam was a good product/solution for this.....
4WDTRK
4WDTRK
sleeps in garage
Thanks for the vid link. Wondering about the drive by wire throttle bodies. Do I need to worry about moving the throttle plate? I've seen videos where they are left connected and moved to full open by turning the key on and holding pedal WOT.
xbauer39
seafoam has a specific can with the spray straw. Disconnect the intake insert straw and reonnect intake...not sure if its any different than regular sea foam or just a different application
Off Road Pedia
