Tell me why I need a Tech 2.
Moderator
People's Republic of Colorado
One thing about having a good advanced-feature tool is that we get to learn and test how things work, not just reset codes or view data pids. The more I understand about how my truck works, or doesn't, the better off I am. The Tech 2 is not the latest and greatest at this point in time, but is certainly an adequate tool for these trucks.
wsteele
Totally agree. If you are a DIYer (at this point I am just a mild DYIer, leaving the heavy lifting to younger techs), owning one of these trucks without a Tech 2 is definitely tying one hand behind your back.
adventurenali92
Big Bear Lake, ca
tis2000 craps out after xp 32bit, so unless you have a dedicated older computer/laptop or run a xp shell (which is slow as ****) then it's not really worth messing with. I suppose there is a need for certain people but unless you have to use it I wouldn't bother. If you do have to use it I would recommend a older pc with max memory and a ssd hard drive, stock windows xp 32bit, has to have a serial port or usb support for a usb to serial adapter. It's probably going to need service pack 2 as well. tis2000 normally needs a dongle but the crack file fixes that.
Good to know thanks for the info! I really have no desire or time currently to run it all on a separate laptop. Lol
O
Oldmopars
Great, thank you. This is the info I needed. I will start looking for one.
Brandon2489
Is this the correct one I need for a 2011 Tahoe LS. Can I program modules with this for Tahoe after 2007 or do I need a required adapter. Thanks for any help everyone.
Jtor95
I have a real tech 2 that was a few grand. But i also have a snap on and an autel. I very seldom use the tech 2 unless i want to see blend door positions. As for reprogramming most scanners will do simple functions. But to program you need to go on tis2web for gm and download software in a j2534 passthrough to program bcm and tcm the tech is a passthrough.
MonteJ
