Roller Rockers
Calderone
they look good but i believe our engines (i have a 96 vortec) must use self aligning.
I prefer non self aligning with guideplates but not sure on your case.
Must use guideplates and hardened pushrods.
When using Roller rockers it's always better full roller over roller tip.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Comp cams have self align full rollers. You should be able to use the 1015-16 set with out any mods. I only could get the magnum roller tip 1.52 for mine at the time. I like them just fine.
99Vortec
Are the Rocker arm studs on modern Vortec 5.7's screw in or pressed in?
My book show's a torque for the 4.3L and 7.4L only.
Cylinder head modifications are awesome.
I once setup an early model SBC with roller rockers, screw in studs, pushrod guide plates, oversized valve springs and chromoly pushrods.
Wound up really fast.
96redsport
96redsport
Altoona, Pa.
So even though these are 1.5 ratio I would still need head modification for the push rod clearance?
retorq
Kingman AZ
The ones posted are NOT self aligning, it clearly says so. Vortec heads need either self aligning rockers or they need guide plates, those are your only two options. You either get the right rockers or pull your heads and mod them to run the right stuff. The ratio isn't the problem.
HeavyHoe03
