Replacing Flexplate, what else is needed
DFletch
I have a 2008 Yukon XL Denali AWD with a 6L80 trans and a 6.2L engine. Since I’m going to be replacing the Flex Plate is there anything I should replace since I’m going to be in there? Also if there’s another Thread that already covered this please point me in its direction because I couldn’t find it
Charlie207
LFOD, New Hampshire
^^^^^^^THIS^^^^^^^
Might also consider getting an upgraded torque convertor.
This is a decent upgrade/replacement: https://www.summitracing.com/parts/ccv-tqbu60fhd
D
DFletch
Thank you for the advice everyone, it is greatly appreciated. Should I do anything with any of these parts as well, aside from the RMS?
What's wrong with the flex plate?
j91z28d1
Thank you for the advice everyone, it is greatly appreciated. Should I do anything with any of these parts as well, aside from the RMS?View attachment 443747
yeah, what's called out as 519. the cover gasket. pretty common leak. most get the new plate with the rear main already installed too.
watch some videos, there's a little bit of alignment to watch our for. they sell alignment tools, but I'm not sure it's needed. Just make sure the rear main is centered before tightening down that plate
if you have it apart enough to get the oil pan down. replace that gasket too. they all leak at some point.
D
DFletch
Recently took it into a transmission shop to get the transmission programmed and they said that the sound the trans was making was from a crack in the flex plate. They said that it shouldn’t be a problem for a while but it’ll be annoying as all heck lol. That’s why I want to replace it
I've cracked 2 flex plates--2 different GM vehicles. It sux. Good move on replacing it now rather then later.
What required the transmission to be programmed? Sorry just curious
No problem, the transmission was replaced but never programmed, I found it it needed to be programmed when the tow mode wasn’t working lol
Hmm, never heard of that normally the transmission will not work unless it is programmed to the vin, tow mode is standard and is just a momentary ground to the bcm, shouldn't need programming for tow mode to work. But maybe I am missing some information?
donjetman
here what I changed when I did the job 6 yrs and 68k miles ago:
Installed rear main seal & cover – Dorman 635-518 - $43
https://www.tahoeyukonforum.com/threads/rear-main-seal-job-pan-etc-07-yukon-denali-6-2.108334/
Performed GM TSB # 10-06-01-008M:
https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
and used Gunk Motor Medic $5 to do the piston combustion chamber soak, replaced:
Valve cover driverside – GM# 12570427 - $117
Oil pan gasket – GM# 12612350 - $36
Oil pickup o-ring – Felpro 72401 or GM 12584922 - $9
Torque Converter – P4646 (gopnh.com) Precision- $218
Tranny front pump seal – GM# 24237531 - $30
Tranny Input shaft seal – GM# 24219390 - $10
AFM Deflector – gm#12639759 - $8
Trans cooler line 1 – ACDelco 15779543 - $16
Trans cooler lines 2 – ACDelco 25999420 - $56
Trans cooler clips- ACDelco# 24205103 - $10
Trans cooler gasket - $7
Front lower plastic cowl - $31
Starter – 6757N - $60
dogbone/barbell rear oil galley seal
mfinta
