Rear end feels like it rolls back on take off
09_4WD_YUKON
Whenever I accelerate faster than normal, it feels like the rear end rolls (rocks) back. I'm thinking it may be a u-joint going bad. My parents 07 Tahoe does the same thing. I searched on google and found possible u-joint issue and "dry" input shaft on transmission. Anyone else have this and fixed it?
kbuskill
NE. FL.
Have you checked all the bushings in the trailing arms going to the rear axle??? There are 8 of them. 2 lower trailing arms and 2 upper trailing arms with a bushing at both ends.
Meccanoble
Georgia
I feel the same thing and was worried it may be u joint related. Since it can be controlled, havent dug too deep...yet.
Big Mama
Virginia
Is it a feeling of delay with or without a clunk sound? If so might just be time to change rear end fluid while you check the bushings k mentioned
Don't google, crawl under there and have a look around!
Don't be like that Millenial in The Mule!
Luggz
