Pulling 05' oem fan and relays...
lowpost99
Lowpost99
Atlanta, GA
Need help where do I cut or from main and get any inline relays from an 05'. Found an owner parting out- wants $20 for the fans. Going to get them tomorrow, appreciate any advice from the gang. I've got an 00' that I want to upgrade. Thanks!
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
lucky ***** fu!@#$
lowpost99
lowpost99
Lowpost99
Atlanta, GA
lucky ***** fu!@#$
That's what I said to myself too! So after I remove the brace I can disconnect the relays there and take all the wiring from there back to the fans. Are there other items that I should take with them?
Chris2144
I've been looking at wiring diagram for that. You should have one ground one positive and 2 wires one for ac command and temp. However adapting it will be a tad bit of a pain as the pcm commands the relays through the ground I have the diagram but can't convert it to post
Chris2144
Check out the how to I posted for adding them to your rig
Chris2144
On the engine side there is two tabs that hold the housing over the fuse box pull it up from there to gain access to everything's
